Question about Samsung Washing Machines
After i wash my clothes there is black little peices all over my clothes and in the bottom of my machine.i have tryed to do a wash with out clothes to clean it but it gets more in there. the first six months we had it all working great but now the black stuff, it like rubber. please can some one help me
    Genius:
  • 1,198 Answers
Look for a filter, it may be breaking down. The supply lines should have screens. If they don't, disconnect them from the machine and run some water into a tub while shaking the lines to see if any specks come out. Once the lines are checked, go down the path, checking each hose for decay inside. Even check the pump impeller for decay. Check the specks to see if they are mold, which could be growing somewhere between the tubs.
Posted on Nov 26, 2013
  • 209 Answers
SOURCE: front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Posted on Sep 19, 2007
SOURCE: Black stuff in washing machine
You need to clean the filter out (look in your machine - it's on the side of the tub) then run a wash with a cup of vinegar in it (or on soak with napisan or something like that in it). It's just gunk build up.
Posted on Feb 18, 2008
SOURCE: Washing Machine smell
The problem comes from the design of the front load washers. There is always a little water left in the tub after the machine is used. Running a bleach load will deal with the mildew until the machine is used again. I leave the door open when I am not using my washer, and this does help.
Posted on Sep 05, 2008
barkencoa
  • 3463 Answers
SOURCE: black marks all over the rubber seal at the front of machine.
The mould you are referrng to is actually bacteria that is building up because you are doing too many low temp washes.
What you must do is a high temp wash periodically,with powder in but no washing.
Do this 3 or 4 times a year, more if you do a lot of wahing.
It is called a maintenance wash, and helps kill off the bacteria.
With a scouring pad or steel wool pad, clean as much scum as you can off the door seal. particularly in the folds of the seal.
You will probably be left with stains in the rubber, but as long as you have got the worst off, it should be o/k.
Please rate my solution.
Thanks.
Posted on Jan 21, 2009
  • 5 Answers
SOURCE: what does de mean on the display of the washing
de means your door isn't closed completely.
The moldy smell is really common with this machine, and maybe all of them, but I have the LG TROMM and was ready to throw away all of my towels. Here's a solution I found that helped alot. First, Clorox makes a solution just for front-end loading machines. You run it through on a cycle with no clothes, that helps to clean it out.
I ran my towels through on the cotton/towel cycle on HOT, with nothing more than white vinegar filling the detergent dispenser. After that, I then ran them through again with just a bit of soap and fabric softener. They came out soft and smelling like new.
I read recently that we all use WAY too much soap in both our washers and dishwashers, even though that's what's recommended in the directions. Excess soap in clothes that doesn't get rinsed out will begin to smell moldy. So I now use about 1/4 of what the directions call for, and they come out fine. I have found, however, that I need to repeat the vinegar cycle once every few months. I think the problem is inherent in that model machine.
And that rubber seal? Disgusting! I clean it out regularly, but when it's full of water after every load of clothes, what do they think is going to happen??? You'll find that Clorox cycle will clean the seal pretty well, though. Good luck!
Posted on Apr 05, 2010
Testimonial: "Thank you so much. You were right - this has helped with the smell. I have had this machine for 2 years now & only just started having this problem. "
My washing machine does not empty the water from the hose, i have checked the hoses when the machine is on its spinning cycle, it only seems if a little bit of water comes out of the machine leaving the...
You need to clean the filter.
Remove lower rear panel of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Reassemble and test.
Dec 22, 2010 | Hotpoint Aquarius WF000 Front Load Washer
No water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
My WP duet washer wont restart after adding a garmet!
Have you tried unplugging the washing machine then start over,this may clear it out and in able you to start fresh.
Dec 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine does not always take the conditioner
take out the soap draw and try giving it all a good scrub mith a tooth brush if that doesent work it could be problem with tap in the back bosch machines are always worth repairing though exellent peice of kit
Nov 11, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Dirty washing
Does your washer smell? Is your rubber door seal gungy too?
If so then use 1/2 cup of Washing Soda Crystals (50p for a 1kg bag from most supermarkets)
set washer to 60 degree wash and run machine for full hot cycle with no clothes in it... just the Washing Soda.
I did this with my washer which literally reeked, and my friends have since done theirs and the results are amazing...
Go and check your drain when you finish too... mine sparkles now and it was gunged up before.. I now add a desertspoon of Washing Soda to every wash.... I place it in the crease of the door seal and little by little all the mould is disappearing, even though the hot wash cleaned the gunge the black spots remained. My washer smells so clean now and no more black flecks on the clothes either... (these are loose gunge from the outer drum, right inside the works of your machine...)
All the best
Sue
Aug 02, 2008 | Hotpoint WF430 Front Load Washer
Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
Apr 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
208 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
