Question about Estate Kitchen Ranges
Oven knob spins in circles no control - Estate Kitchen Ranges
    New Friend:
  • 52 Answers
There should be a metal spring cip ring around the spindle of the knob which keeps it tight around the spindle on the switch. Sounds like its snapped. Compare it with one that works, they should just pull off and push back on, but with a little bit of resistance.
Posted on Nov 26, 2013
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
Need to replace manual LH side mirror control bezel.
You do not need a part number
You go to a dealers parts counter &
buy what you need
Jul 17, 2012 | 2003 Chevrolet Malibu
My ps3 controller has a r2 rapid fire mod in it and now the right analog stick just makes my mw2 character spin in circles what can i do?
Push down on the top of the knob,like the R3 button on PS2,not down directional,and spin it in circles at the same time.I just basically go spastic on my controller for about 5 second bursts and it always gets rid of the spin.Your R2 may be stuck too.Push on it real fast a few times and it should unlock.If the R2 does not stop,you probably need a new controller. :(
Good luck and game on!
Jul 25, 2010 | Sony Dual Shock 3 Controller for...
Knob on oven is not working properly
The knob is probably cracked, if you can pull it off, then you can try to see if you can turn the oven off with a pair of grips or pliers, if you can, then you just need to replace the knob, if not then you will have have to replace the switch.
Feb 01, 2010 | GE Ovens
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Delonghi esf461st built in fan oven. No operating instructions. What does the middle knob do? It has 4 settings, one for the light one for the grill and 2 more, which must relate to the oven function. One...
The setting with the fan is fan only function.
The setting with the fan and circle is for fan and element for heating the oven.
Please rate my solution.
Thankyou.
Jan 13, 2010 | DeLonghi Ovens
The teeth that the setting knob engages with are worn down. these are located in the panel circling the metal stem. how to fix
If you are talking about the control knob to set the desired cycle you can use a two part apoxy in the hole on the knob being sure the knob is in the correct position before appling the knob with the two part epoxy(this is very important) Let it dry and the knob should not spin on the shaft anymore.
Jan 12, 2010 | GE WBSR3140DW Top Load Washer
Heli max hicro helicopter just keeps spinning in circles
Spinning is caused by one of the main propellers rotating faster than the other. If both propellers are secured tightly to their drive shafts, the spin control knob on the remote control can be used to stop the spin. However, if one prop is slipping with respect to the other, the spin control knob will not fix the problem.
I've found that the set screws holding the propellers to the drive shafts tend to loosen after a while. If one prop is a bit loose and the other is tight, the relative slippage will cause the helicopter to spin.
To check, turn off helicopter power and manually rotate each propeller separately, watching the nylon gears in the body. If the propeller is moving and its drive shaft gear isn't, the propeller is slipping because its set screws are not applying enough pressure on the propeller's drive shaft.
Carefully tighten the set screw and the problem should be fixed. DON'T OVERTIGHTEN, or the plastic threads for the set screw will be stripped and the propeller assembly will be ruined.
Apr 10, 2009 | Max Heli- Axe CX Micro Electric Rc Mini...
Zansuai
If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 07, 2008 | Zanussi TC7114W Electric Dryer
Zansuai
Nov 07, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Kitchen Ranges Logo
73 people viewed this question
Top Estate Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you an Estate Kitchen Range Expert? Answer questions, earn points and help others
