Question about Dewalt DC825 Cordless Drill
Desalt dc825 motors runs and comes on just fine but i was using it and it seems like a gear is stripped because theres no power to the saft
    Habit-Forming:
  • 188 Answers
Ereplacementparts.com has the breakdown of this
Posted on Nov 29, 2013
2 Suggested Answers
budgie140
  • 501 Answers
SOURCE: HOW DO YOU PULL THE CHUCK OFF TO GET TO THE GEARS
if its a reversible drill,you open the jaws wide,and undo the left hand threaded screw inside the chuck,then put the the chuck tool in,and use that to unscrew chuck off the thread,right hand thread
Posted on Jun 29, 2010
Audi a4 alt motor sounds like running on 3 cylinders
Robert your going have to check the oil pressure the oil pumps on these engines tend to let go. What happens the key way that drives the gear strips and at low rpms it doesn't pump oil to the top of the motor but when you rev it the gear spins a little faster that's why it makes less noise you will have to replace the oil pump. As for the missing the hydrolic lifters are no working properly because of the low oil pressure.
Jan 31, 2014 | 2006 Audi A4 2.0
What is wrong with my dewalt dc825 if the motor works but shaft is not worting like theres a gear stripped inside
Yes, the gears get stripped inside. Usually caused by shifting while the tool is energized.
May be under warranty, check with tool repair shop.
Nov 26, 2013 | Dewalt DC825 Cordless Drill
The first time I used my new pasta roller I seem to have burned up something in my Kitchenaid mixer. What happened?
First Question that comes to mind, is the motor even running. If it is and there is nothing visible moving, you probably stripped the gears in the head of the unit. If the motor doesn't run, the brushes may have coincidendally worn out. Need more information. Reccomend taking the top cover off while it is unplugged and checking the gears and brushes. The Plastic gear (When I got mine) was a bit pricey, but a lot cheaper than a new mixer. If you wore out the brushes, You may just want to consider a new machine since you evidently got a lot of use out of it. Almost everything is replaceable in the mixer
May 22, 2011 | KitchenAid Pasta Roller & Cutter Set...
Blades do not rotate, motor runs
Something is stripped. Most shredders are gear driven from the motor to the driver shaft and onto the driven shaft. Check that the motor has not come loose from its mountings, the drive gear has not come off the motor or the gear has stripped. You will have to split the shredder housings to do this.
Feb 22, 2011 | Fellowes Office Equipment & Supplies
Olympus SP-350 will not power on anymore. Battery is fully charged. There is a light buzzing sound coming from the battery slot when you push the power button. Camer was never dropped nor wet. I took a...
not sure - but seems like you have a power on issue, so try to check into the battery bay and see if there's any dirty stuff or leak from battery or just make sure the contact is clear.
Using a meter to double check to know that the batteries are BOTH charged is advised. The Buzzing noise seem to indicate the motor is having problem extending the lens or the motor's gear is stripping hence making the noise?
Feb 20, 2011 | Olympus SP-350 Digital Camera
My Craftsman 1/2 HP Garage Door Opener stopped working. The motor is running but chain isn't moving. The actual door goes up and down fine.
Remove the cover and take a look. I'm sure you will find the drive gear is stripped. It is a white nylon gear just in front of the motor. You can buy one at any good door service company. The part number is 41A2817 and it comes with instructions.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Yz 250 2008 possible 5th gear stripped?
I doubt that any gears are stripped. Believe me you would have known it when it happened at 40mph which is where you would have to be in 5th gear. This is a bent shift fork. The actual gear is fine. The slider gear is not moving far enough to engage with 5th gear. The YZ does tend to have this problem in 5th and 1st. "Dirt rider Magazine " did a story on it. Best to let the shop do the repair as the entire motor gets torn down into about 100 parts.
Please rate this solution. Thanks!
Apr 08, 2009 | Yamaha YZ 250 Motorcycles
Dewalt DC825 Cordless Drill Logo
140 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
