Question about Dewalt DC825 Cordless Drill
What is wrong with my dewalt dc825 if the motor works but shaft is not worting like theres a gear stripped inside
  • 4,341 Answers
Yes, the gears get stripped inside. Usually caused by shifting while the tool is energized.
May be under warranty, check with tool repair shop.
Posted on Nov 26, 2013
5 Suggested Answers
1SANTA
  • 5 Answers
SOURCE: gear slipping in dewalt dw056
You can go to dewalt online and buy replacement parts.
Posted on May 22, 2009
SOURCE: Impact not working correctly
The pinion on front of motor is slipping on motor shaft. It seems to be just a press fit. Seems like a flaw in design. I had same problem. I took the dw056 apart and took pinion off motor and pressed groves into motor shaft with side cutter pliers. then pounded pinion back onto motor shaft. We will see how long this lasts the motor shaft is a softer metal. I feel the motor shaft should be hardened steel like the pinion and have a shear pin or some sort of spline to attach to pinion. Would like Dewalt to offer fix for this as I only used dw056 a couple of times before I had problem.
Posted on Jul 31, 2010
barterjoe
  • 338 Answers
SOURCE: How do u take out the parts on the inside of the
This image is a reference: http://documents2.dewalt.com/documents/English/Exploded%20Art/EA023487.png Number 9 is a retaining ring that will come off and let you take the hammer out. It is recommended to use the service tool item # 836 but it is on backorder at the factory level currently.
You may be able to pick the ring out of the quick coupler.
<img src="http://documents2.dewalt.com/documents/English/Exploded%20Art/EA023487.png" style="opacity: 1; width: 100%; ">
Good luck
Joe
Posted on Feb 15, 2011
  • 192 Answers
SOURCE: dewalt dc825 does not run
Look online from there site.Need new one.
Posted on Aug 12, 2012
Dewalt dc825 does not run
Aug 12, 2012 | Dewalt 18v Cordless Impact Screw Driver...
How to replace Dewalt cordless drill brushes
The brush holders & brushes for your DC825 are only sold as an assembly and the left and right sides are different; Dewalt part number 640550-00 for the left, 640555-00 for the right. They are accessable only by splitting the clamshell and easy to replace once you get to them.
Mar 02, 2012 | Dewalt 18v Cordless Impact Screw Driver...
How do u take out the parts on the inside of the cone on a dewalt dc825 impact???
Good luck
Joe
Feb 15, 2011 | Dewalt 18v Cordless Impact Screw Driver...
Jun 05, 2010 | Dewalt DW056 18 Volt Cordless Impact...
Demolition tool or breaker
The shaft from the motor to the drive gear is likely not working the action of the hammer. There is a gear which spins the gears to achieve the hammer action, suspect the gear is either stripped, broken or both.
Jan 17, 2010 | Dewalt D25330K 2KG Sds Plus Demolition...
Gear slipping in dewalt dw056
Those gears are only held on the motor with their tight fit, if yours is slipping that easily the motor will have to be replaced. The new motor will have that gear on it.
Apr 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt DC825 Cordless Drill Logo
232 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
