Question about Pari Proneb Ultra II Compressor Nebulizer System
Chord connects to the machine broke off
I need another replacement chord. My machine is about 6-7 years old
Philips TV freezes or turns on/off continuously
please check on mains chord and plug or even better the plug itself by connecting another lamp to see it flickers meaning something wrong with the AC line in.
1.either replace mains power chord
2. also see solder connections inside TV that is if you know something about mains take care to switch of mains and disconnecting main chord
happy hunting
Sep 12, 2015 | Philips Televison & Video
Used it last year.This year the chord to the extension chord frayed in two places.From the handle.And where the outside extension chord connects
I take the old wires out and replace them An electrical shop should have the cord you need. The switch on the handle should come apart and go back together again Just becareful you put it back together the same as you took it apart.
May 01, 2015 | Garden
Broken pullcord . cord is missing how long should new cord be and how hard is it to replace
Just went through this pain today. Here's how I did it. Use allen wrench with T handle to remove the shroud over the carb controls and plug. Then remove about 10 screws and split the case. Use tool that comes with the unit to remove the nut holding the impeller. Behind the impeller, use torx head to get the other bolts to remove the motor. There are two other screws on the other side that hold the motor on. Drop the motor from the case carefully. It is still attached by wires to the throttle and kill switch. Note how the throttle linkage is connected because it will come apart for sure. On the one side of the housing you are looking at the plastic cord spool with the spring unit behind it. My chord simply pulled out of the spool. It was held on with a 10mm nut and start washer (not a good design). If the chord broke, remove the remnant from the take up spool. To rewind the new chord or replace the one that pulled free, you need to wind the spring to put tension on it. Make sure the take up spool engages with the spring tang otherwise it will turn free and not tense the sprint. Once engaged with the tang, the spool should set to the bottom to be level with the metal chord guide. Turn the spool clockwise 3-4 turns until you feel it tighten. With a 2nd pair of hands, hold the tension on the spool and tread in your chord. Route the chord through the take up reel into the hole on the side. Loosen the 10mm nut with the star washer and route the end of the chord through it. Tie a simple knot in the end to prevent it from pulling through. Tighten the 10mm nut which clamps on the chord. Now, slowly, let the spring tension take up the loose chord until fully retracted. Make sure the metal chord guide fits in the slot to channel the chord properly into the take up reel. Hold the spool down and give the chord a gentle test or two. The chord should retract easily and fully. Simple as pie!!! Reverse the disassembly and you are back in business.
Apr 01, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Hi, I have a hp psc 2410xi photosmart and I can't get read of the eroor message remove and check your ink cartridge. Please help
1) connect printer directly to wall
2) try with different walloutlets
3) remove the cartridge and the clean the copper contacts with a lint free cloth
4) then unplug the power from the back of the printer and then press and hold the power button for 30 sec then release the button.plug in the power chord.
5) then unplug the power chord from the back of the printer.. press and hold down the (#) pound and 6 key together and then without releasing the button plug in the power chord.. once power chord is plugged in release the two buttons..
then check what happens.
6) try replacing ink cartridges
7) if it does not work service the product
Mar 26, 2011 | Office Equipment & Supplies
I broke the pull cord on my generator; how do I
you should remove the housing usually 4 bolts
dont remove anything else then look at the pully and remove the old chord tie a knot in the new chord and slot it into the hole on the pulley
you should then see a notch in the edge of the pulley this is for the chord to sit in while you turn the pully enough times to tension the recoil spring once tensioned enough so that it recoils all the chord slot the chord through the hole in the outer casing through the pull hande and knot it job done then refit
May 09, 2010 | Electrical Supplies
So i have had a ps3 for about 2 years now and the hdmi chord worked fine for 1 year and then all of a sudden i started lossing signal from the tv. If i wiggle the hdmi chord the picture will sometimes come...
Hi friend, see since your regular (component/composite) chord worked well so the problem is with your HDMI chord. It is losing connection with some internal wire try to use another HDMI cable if it still not works so problem may be with your HDMI port.
Composite/component cable works fine but the cost of graphics..... but still HDMI graphics are just too good...
Hope it will work for you.
Jul 09, 2009 | Video Game Consoles & Games
Joystick control wont work
Probably not. Make sure that the connectors are pushed together fully.
May 05, 2009 | Pride Jazzy Select 6 Indoor Power...
Black stripe down center of document
as you have cleaned the scanner glass..try these steps..
1)connect the printer to the wall outlet..
2)then try to make a copy..if you get lines..then go to next step..
3)unplug the power chord..press and hold OK and CANCEL button together..while pressing the buttons plug in the power chord..
4)after you plug in the power chord do not release the button till the screen goes blank..once its blank release the buttons and then turn on the printer..
5)try to make a copy..its still the same..it is a hardware issue..machine should be replaced
6)Call HP who would give u a rebate on old printer & replace it with brand new printer.
Mar 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
How to replace an antenna on a 1988 honda accord.
Ouch! I haven't tried this myself, but would electrician's tape work? Try feeding it from either end...
Jan 20, 2009 | 1988 Honda Accord 4 Door
Power problem
If you bought it brand new and is only 6 months old, I would suggest to contact the manufacturers to get repaired under warranty since most electronics devices carry one year warranty.
Good Luck.
Oct 03, 2008 | Behringer EUROPOWER EP2500 Amplifier
Pari Proneb Ultra II Compressor Nebulizer System Logo
35 people viewed this question
Top Pari Health & Beauty Experts
xalint1
xalint1
 Adam D
Adam D
Level 1 Expert
Are you a Pari Health and Beauty Expert? Answer questions, earn points and help others
