Question about Sony Handycam CCD-TRV107E Camcorder
Help When I open my lcd screen in my camera the pictures is upside down, is there anyway I can adjust it back? Please Help
  • Anonymous Apr 29, 2008
    I have the same problem with my Sony handycam DVD recorder HELP
Press and hold reset button for 30 seconds.
Posted on May 15, 2008
The LCD turned Upside down
Try resetting the camera bt removing the battery for 20 mins, then replace the battery and go into the menu and set the Date & time.
Jun 08, 2012 | DXG Technology DXG-305V Digital Camera
I got cryptic answer regarding the problem that the picture on the monitor on my camcroder GZ-HM400 is upside down.
There is a switch within the camera that controls the orientation of the LCD image. When the screen is flipped upside down, the switch is supposed to tell the camera to flip the image upside down as well. If this switch is damaged, the camcorder gets the wrong signal and the image will be displayed upside down. This can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 25, 2010 | JVC Video Cameras
LCD PICTURE UPSIDE DOWN
This is a feature not a bug...The LCD is designed to flip the picture when you rotate the screen. This is so that you can see what you filming or be in the picture and see yourself filmed. I can't remember if it flips automatically or not. But, I would first try inverting and reverting the LCD screen to see if you can get it to detect orientation, then check and see if there is a setting to manually set the orientation of the LCD instead under the menu options.
May 05, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Flex Cable replaced-but now VF is dead, plus...
Hi, I have just repaired my camera following the excellent series of pictures provided by airshod, and I think the viewfinder problem could arise from replacing the tiny board under the D panel covering the lcd panel hinge. This panel has a tiny switch activated by a little projection on the lcd/hinge moulding and on reassembly it is necessary for the panel to be open and at right angles to the body so that the projection is on the right side of the switch for correct operation. I assume that it is this switch which activates the changeover from lcd to VF. It could be that if the lcd panel were closed while asembling the D panel the switch could have been damaged while opening it later, but the board would be easy to replace - the supplier of the cable should be able to obtain a replacement. I'm not sure about the upside picture problem though, it may be related to this but without a service manuel it's hard to say! Good luck!
Aug 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Images on LCD are upside down.
You have to go to settings and adjust from there...find LCD settings and that should do it.
Jun 10, 2008 | JVC GR-D770 Camcorder
Camera
If you're looking at the face of the phone, there will be volume adjustment buttons on the left-hand side. While using the camera, try pushing those buttons to get the picture back to the way you want it. The top button (volume up) will flip it upside-down or right-side-up. And the bottom button (volume down) will do a mirror image effect.
Apr 05, 2008 | Samsung SGH-T519 Cellular Phone
Samsung E250 Camera Phone Problem
Press the volume button while camera works!
neparkiraj
Feb 04, 2008 | Cell Phones
Picture is upside down and backwards
I have the same problem. How and where does this come from? My camera was sitting in the dock when I noticed the problem!!
Nov 26, 2007 | Kodak EasyShare C315 Digital Camera
Picture reversed and upside down on screen????????
just happened to me, phoned customer support and solution is to press the Ctrl key and Alt key and Up arrow together and it should solve the problem
May 02, 2007 | Toshiba SD-P1200 Portable DVD Player
Sony Handycam CCD-TRV107E Camcorder Logo
106 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
