Question about Blomberg DWT35240
Drain pump does not work - Blomberg DWT35240
Why the washing machine Not drain after finish cycle work
I suggest to check filter, drain pump, drain hose, wiring ane element which control drain cycle (electronic or programmer).
The simplest would be to download the drain hose and turn it in the bathtub or sink, and then run a short draining program.
If you hear the pump work and the machine doesn't drain water then is a mechanical failure, for example; foreign body in the filter or in the drain pump turbine, crimped or blocked drain hose. Also, could be clogged drain pipe in the wall. If you do not hear the pump work then is obviously a electrical malfunction.
Dado
Jul 25, 2015 | Washing Machines
Washer will not drain water frigidaire
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please revert for any further assistance.
Hope this helps...
Daniel
Feb 17, 2011 | Washing Machines
It will not drain!
Hi
Hope this helps...
Daniel
Jan 13, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Water is not pumping out of my fisher and paykel top loader
Hi
Hope this helps...
Daniel
Jan 10, 2011 | Fisher and Paykel GWL11 Top Load Washer
My washer will not drain?
Hi
Hope this helps...
Daniel
Jan 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washer will not drain the water is there anyway to manually drain it
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Washing Machines
My washer wont pump water out hose is not blocked
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please back for any further assistance.
Daniel
Nov 26, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Will not drain before spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you’ll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. If it still doesn’t work then you would need to replace the drain pump. Please revert for any further assistance.
Daniel
Aug 30, 2010 | Washing Machines
Wont drain
Hi
Daniel
Aug 28, 2010 | Whirlpool Washing Machines
Will not drain the water and spin
this unit will not spin until the water is drained. your pump is jammed or faulty.if u r confident, remove and clean pump.please turn off power b4 u work on it do want any accidents . please reply if u need more help
Apr 08, 2010 | LG Washing Machines
Blomberg DWT35240 Logo
19 people viewed this question
Top Blomberg Dishwashers Experts
Andrew Taylor
Andrew Taylor
ray gallant
Dale Copeland
Dale Copeland
Are you a Blomberg Dishwasher Expert? Answer questions, earn points and help others
