Question about Kenwood MX270 Patissier Food Processor
Got electrical supply but not functioning - Kenwood MX270 Patissier Food Processor
Instruction manual for Prinetti multi function food processor blender juicer
Hello, You will have go back to Prinetti, cust service to get the manual that you want.
May 16, 2014 | Food Processors
Motor will not start
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 10, 2014 | Cuisinart DFP14 Food Processor
Won't start;
A possibility that the micro switch inside which is actuated when you put the top on......the one you are tooth picking....has become dislodged, or the grooves that the switch hold it in place have broken off. Is there anything rattling inside the mixer which would suggest that a piece of the casing has broken off. If you can disassemble it to this point where you can see the switch and there is damage around that area which makes the switch loose, you could use some hot glue to hold it firmly in place. Let the hot glue set solid before you use it.....especially as the switch completes an electrical circuit and hot glue in its liquid form s conductive! Always remember to remove the electrical connection before opening the unit. Failing this, it could possibly be that the switch needs replacing which is a far easier job. Switches are pretty comparable regardless of what brand mixer. Sometimes held in with a screw on opposing corners. So even eBay would probably have one. Good luck. On the bright side, your solution works, but on the dark side, using a plug socket to switch a unit off and on is tricky! Saranden.
Nov 24, 2013 | Cuisinart DFP-14BC Custom Food Processor
I would like to buy a manual for my Rival Electr-o-matic slicer. Does the company have a web site where I can dowload one?
Depending on model, I can offer a free digital copy in PDF format; I have manuals for models 1005, 1010, 1025, 1030 and 1101, though perhaps not identical for your submodel (for example, 1101E/05). Email request to lallin@juno.com
I also have new, functional replacment parts are available as follows: Newly manufactured rubber suction cup feet, sold in sets of 4; nearly 200 sets have been sold to very happy customers. Replacements for the thumb nut used to secure the blade; look different but work well. email lallin@juno.com for more information
Jul 07, 2011 | Food Processors
I plug it in, turn it on, the red light goes on but nothing happens. same thing when i hit pulse. Any ideas what could be wrong?
hello,
the problem is from the connection i.e power connection
that supply electrical force on your processor
this means that there have been a power fail on the propeller ,
what you need to do tofix up this problem is to unscrew the processor then trace the wire down to the propeller you will fine the disconnected wire from the propeller then fix back to the propeller unit but if there is no sign of disconnection from the connection then it means that the wire are weak ,
it will need to be replace with a better one which you can get in the store.please note before you can do this assignment you will have to put off all source of power supply to your processor
thank you.
Jun 13, 2010 | Cuisinart DLC-2014 PowerPrep Plus Food...
Will this appliance work in England
If the power requirements for line voltage are compatible with the UK supply, then yes it will work. If the unit was designed for 120-volt operation in the US, then no. You'd burn it up on the UK 240-volt power system.
Jun 01, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Robot Coupe clicks, runs 5 seconds, stops for 30 seconds, clicks, runs 5 seconds...
The clicking noise is an internal circuit breaker or motor protector. These things are not made to be bogged down or overfed. The motor is heating up & tripping the overload, after cooloing it resets. Time to buy a new one or get the motor replaced ($600-$800)
Oct 29, 2007 | Robot Coupe R100 10 Cups Food Processor
Braun K 750 CombiMax 8.45
unique services
mumbai -400008
ph no -23051554 \ 23095757
Sep 17, 2007 | Braun K 750 CombiMax Food Processor
Kenwood MX270 Patissier Food Processor Logo
23 people viewed this question
Top Kenwood Food Processors Experts
tfelton3
 Mikey
Mikey
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
