Question about Craig CLC501 15 in. TV
I have a bussing noise on my sound on my TV. The picture is great I can hear the sound kind of but not good. How do I fix it?
  • 2,113 Answers
Look for a fixed coil and put some epoxy on it.
Posted on Nov 26, 2013
Philips magnavox,9p5040c102 tv has power but no pic or sound, what is wrong, worked fine yesterday
I have same problem with mine, the power button turns red (as usual) but no picture. When i turned mine on last night it made a crackle noise and thats how it all started. I can even hear the normal sounds it makes as if it were turning on, but still no picture. Its a great tv I would hate to throw away. I want to fix it myself any help would be appreciated!
Aug 21, 2011 | Philips Magnavox 51MP392H Rear Projection...
Philips 47" lcd tv #060958514738, it is less than
what you need to do is go into the equliser and adjust the settings till you are happy with it this is the only way to do it i would also maybe advise a surround sound system for around 70 dollars as you said your picture is great you may as well get surround sound to go with your home cinema experience the problem is it depends on ur hearing you may be able to adjust the equliser this would solve anyones problem but with some people their hearing is a bit more selective the tiny little speakers used in these systems make annoying background noisethe only thing i could advise is a surround sound sytem if you still notice it when you adjust the equliser but trust me it is not ur tv it is how good ur hearing is i hate a tv with tiny speakers
Feb 25, 2011 | Philips Televison & Video
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
I have a wd52628
This area of the TV is a cause of some expense in rear projection.
The fan controls the temperature of the lamp. An obstruction keeps the fan from coming up to speed.
The power block controls the power the lamp uses. This helps keep the glass of the lamp from breaking breaking.
An arc is a badly mounted lamp or a lamp defect.
Dust build up can cause overheating.
Most of this area cannot be serviced by a non-technician.
Apr 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
My sony 27 Trinitron KV27FS100 has a great picture but no sound
HELLO. SOUND'S LIKE U HAVE A BAD SOUND BOARD.!!! U CAN HOOK UP TO A HOME STEREO AND GO THROUGH IT FOR YOUR SOUND.!!! GOOD LUCK!!! LET KNOW IF THIS HELP'S YOU.
Jun 05, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No Picture but have sound
OK I got my first TV, first to repair myself that is, and I have no training at all but am kind of a tech dork wannabe. So I checked and I have sound but no signal through the TV tuner, so I hooked up my Zenith VCR to aux 1 and sound with signal appeared, the VCR tuner still works :) so I am leaning toward the TV tuner. It is visibly damaged, and I'm hoping it is as simple as a broken connection. I also noticed a vertical flash and pattern of horizontal lines when it is turned off (white). sooooo I push on.... help!!!!!!!!!!!!! :>}
May 02, 2008 | Televison & Video
Sanyo 24inch TV
Sounds like you have a bad speaker,or at the most the audio amp needs changing. Get old speaker out of another tv or stereo.
Oct 04, 2007 | Televison & Video
Funny noise on LG TV
This is a problem with alot of TV sets. Most of the time, women can hear this alot better then men because they have better hearing then men. There is what we call in the buisness, a "singing coil". The problem could be simply the coil is singing and will need to be replaced because the windings of wire that makes up the coil is not wrapped tight enough or this noise could be the sign of future problems to come as a bad switching power supply capacitor or a capacitor going bad. I am sorry to say there is not alot an end user can do except call out a tech to have a look. Good Luck
Mar 21, 2007 | LG 42PX4DR 42 in. Plasma TV
Buzzing Noise and TV picture is yellow
Andy, I'm thinking the buzz is from the deflection coil (yoke) on the neck of the tube or the power supply. Probably not the high voltage as you can hear the "buzz". If it's really that annoying, you can take a length of rubber tubing (no metal) and listen to the buzz coming from the chassis kind of like a stethoscope. STAY AWAY FROM THE HIGH VOLTAGE, please. The yellow picture sounds like a blue chroma failure. A tube can be rejuvinated if need be but that's a job for a pro. Hope this helps.
Oct 30, 2006 | JVC AV-27220 TV
Craig CLC501 15 in. TV Logo
56 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Henry  Thomas
Henry Thomas
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
