Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
My hot tub is not coming on at all and is giving me a Pr code. What can I do?
My hot tub is not coming on at all. I am getting a Pr code. Took filter out and still have same code
  • Qca Spas Master
  • 1,631 Answers
Very simple...
Pr is only a brief "timeout" upon powering up the hot tub control system. Pr means - "Priming" Mode. That's it!
it will be in this mode for about 6 minutes.
Then system will revert to normal operation mode.
Good luck.
Posted on Mar 15, 2015
    Top Expert:
  • 12,223 Answers
Please follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical panel or the electrical panel . Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
my hot tub is not coming on at all and is giving m - 9d4832d5-8a31-4a17-99b3-af20b93aa530.jpg
Posted on Nov 26, 2013
Filled hot tub with cold water but error 98 comes up on display saying water to hot and wont reset
Julie Palmer... hello,
Somewhere you got a THERMOSTAT that is giving a bogus reading (on a fairly nominal temperature)...
You are going to have to find it... and most likely replace it.
https://www.bing.com/search?q=hot+tub+thermostat&form=EDGEAR&qs=PF&cvid=6bf0d109ca4a4c49b09ff562b296ea64&pq=hot%20tub%20thermostat&PC=DCTE
May 25, 2016 | Pool & Spa
Hot tub stuck in PR mode.
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Mar 27, 2014 | Pool & Spa
Great lakes hot tub
Hi, I am not a hot tub expert and I don't know what PR status is or what PL on the display means . However I did a quick search for you and have a web address that might help you find a solution.
http://www.spacare.com/troubleshootingguideforspaandhottubs.aspx
Hope it helps you
Regards
Steve
Mar 27, 2014 | Garden
Error code PR
pressure either switch or recirculation pump
Feb 16, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
I am getting a Pr code and the tub is not coming on at all
If the unit won't start, make sure power is on at the electrical outletor the electrical panel Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
Nov 26, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
My Dream Maker Big Ez is displaying error code Pr on display when the display is on at all. Worked fine before. This just started overnight
pr is for primeing the pump hit the pump and see if it goes off if not hit the temp botton up or down and see if thjat works for you
Nov 08, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
232 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
