Question about Microsoft Windows XP Professional for PC
Computer never continue to start up, it just continue restarting at least 2 times then it hang. when i try to reboot monitor never display any images anymore and what i noticed when that happens is that the keyboard 3lights keeps blinking. when i unplugged everything leave it for sometime (atleast 30 mins) then try to power it on again, the monitor shows displays again but still not continue to start up then just same problem happens again, it hangs restart 2 times then monitor will not display anything again... im very much exhausted with this.. what seems to be the problem??? HISTORY: ooops i almost forgot, before my computer reached that "useless state" it continues to start up. dat time ill be able to use my computer for 15-30 mins then it hangs or suddenly restarts... the BSOD that appears tells me something bout nv4_disp yada yada.... im no pro with this... i dont know what else to do... pls help me asap.. heres my computer specs: P4; WinXp service pack2 512MB DDR 40G Samsung HDD 128MB inno3d 64bit VideoCard 300W PSU hope to here from you guys ASAP... thanks...
  • 4 more comments
  • jeidy16 May 08, 2009
    JKPF:
    my CPU fan spins i know that coz ive tried powering it on with the chasis open..
    RJBEG123:
    cant do that now, i will later when i get home..
    * im wonderin whats d main problem thats causing this malfunction to my computer... grrrrrrrr....... i am very frustrated...
    both... it sometimes freeze while im configuring BIOS setup, sometimes it happens after windows
  • jkpf May 11, 2010
    May I ask, the freezing, usually before windows boots up or after
  • jkpf May 11, 2010
    There is a high possibility that you computer's CPU fan isn't working. Can you open the chassis and turn on the computer to see if the CPU fan still spins?
  • rjbeg123 May 11, 2010
    Try unplugging your keyboard and starting with it unplugged and let us know what happens.
  • 413 Answers
Run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
Posted on May 08, 2009
Our samsung lcd monitor went black! two weeks ago, it does not display anything. so we, turned the system off then we turned it on. after doing so, the monitor worked properly. unfortunately this week,...
this could be a loose lead or a faulty connection
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connections and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Oct 30, 2011 | Computers & Internet
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
When i start computer there is no display on the monitor. when i restart computer many times(4 to 5 times) then display is shown . i also changed my RAM
How about try changing your display setting, go to control panel. Double click display icon, click settings, click advance and monitor. From your monitor settings change screen refresh rate to 60 Hertz and click ok and ok. Try to restart your computer and observe.
Sep 22, 2010 | Intel Pentium Dual-core Processor E5200...
SOYO DYLM24E6 DISPLAYS OUT OF RANGE WAS TOLD MONITOR HAS A RESET BUTTON IF SO WHERE OR IS THERE A FIX FOR THIS MONITOR IT IS NEW
Restart your computer in Safe Mode
(or reconnect your previous monitor).
Set the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, connect the new monitor, and restart, and your Soyo monitor will be able to display something, using these "NOT-out-of-range" values.
Try changing the resolution to 1024-by-768, or 1280-by-1024,
and "test' these values, to see what values are "in-range" for your new monitor.
Jan 07, 2010 | Soyo DYLM24D6 LCD Monitor
I have LG 700S 17" Monitor
Try tapping f8 when you start your computer and when at the MS startup menu choose
  • Enable low resolution video (640x480)
  • and if windows starts update your video driver and that should fix the problem, when you restart more than once the options go back to default (not low res video,whatever video driver is installed)
    Mar 12, 2009 | LG Studioworks 700S 17" CRT Monitor
    Restart computer and monitor says not optimal display
    If you are indicating you have like 5 or 10 frames stacked across the screen causing the can't see problem, here's the "what-to-do". Reboot the computer and use "F-8" to get it started in safe mode. Make the necessary corrections the the display settings. Save and reboot. That should restore so that you can see to optimize the settings once back in normal mode.
    Let me know if I missed it.
    Feb 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
    Unable to install HPw2007 Monitor
    I would like to inform you that if you are using HP PC, then there is no need to install the drivers from the disc provided with the monitor. HP PC already has in-built monitor drivers. The default account in Vista from first boot is an admin account, monitor should plug and play and the correct INF file will install for the monitor.
    Still, if you want to install the drivers from the disc provided with the monitor, then please follow the steps given below:
    == Disable UAC settings ==
    You might get access denied error message while installing the monitor drivers.
    The error message might come up if the UAC (User Access Control) in Microsoft Windows Vista is kept enabled, hence not allowing the installation.
    To resolve the issue please follow the steps given below :
    1. Click Start
    2. Click Control Panel
    3. Click User Accounts and Family Safety
    4. Click User Accounts
    5. Click Turn User Account Control On or Off
    6. Uncheck the checkbox
    7. Click OK
    You will need to restart your computer for the change to take effect.
    Now try to install the monitor drivers and check for the results.
    If still the issue persists then :
    Step 2 :
    1. Click Start -> All Programs -> HP My Display -> Display Diagnostic Utility.
    2. In the Display Diagnostic Utility click on “Clear Registry”. A Clean Reg Window would open, Click on “Yes”
    3. On restart you will have “Other Devices” with “Generic Monitor” List under that same.
    4. Continue the process of “Clean Registry” until you get “Other Devices” with “Generic Monitor” listed under that same.
    5. Now insert the disc and install the drivers.
    or Download the HP w2007 LCD Monitor Driver from the weblink provided below :
    ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39950.exe
    Now install the drivers.
    6. Restart the computer.
    7. This time it says "new hardware found with recommendation to install".
    8. Cancel it.
    9. Immediately, it gives option "Do not show the message again" and also says computer won't function if we select it.
    Proceed by check marking it. You may be prompted to check mark it twice if prompted.
    10. Restart the computer to check for the error message.
    It will no more ask to install the monitor drivers.
    Take your time, please try the steps and get back to us with the results.
    Jan 24, 2009 | Microsoft Xbox 360 Console
    Display problem in my LG 15'' monitors
    1. cheak the filament path diode,capacitor.
    2. there is dry points in power section.
    3. replaced 3842 IC supply capacitor 47/100v.
    4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
    Nov 22, 2008 | LG Studioworks 563N 15" CRT Monitor
    Display Problem
    run device manager remove complict display adapter.. then restart...
    Mar 28, 2008 | Sharp LC 28HM2 28 in. Flat Panel LCD...
    Funny monitor problem
    If I were you I would invest in a new video display card. Sounds your card is intermittant, because the chances of a tube type display and a TFT display having the same problem is slim to none. LOL Good Luck Please dont forget to rate this thread
    Oct 20, 2006 | Samsung SyncMaster 540N 15" LCD Monitor
    Microsoft Windows XP Professional for PC Logo
    142 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
