Question about Philips DS9000 Primo Speaker Dock for iPod/iPhone
Philips ds9000 stop working no power
No power from the system I plugged it in one day and it stopped working no output from ds9000
2 Suggested Answers
  • 400 Answers
SOURCE: Philips home theatre system hts35650 stoped working After switched off the power. How to fix it
Perhaps the surge strip has blown a fuse. Try plugging directly into a wall socket, bypassing the surge strip. If it lights up, then you know you have to get a new surge strip. In any event, it is most likely a fuse that's either in the surge strip itself or in the rear of your Philips receiver, near where the AC plugs into the chassis. All electrical appliances and devices have a fuse. Find it and take a look and see if you can ascertain if the nicad wire is broken inside.
Posted on Jan 08, 2015
Jan 08, 2015 | Philips Audio Players & Recorders
When plug in power cord, set turns on demo mode.No respons when press standby/on butten. By pressing tuner or any function butten, set turns off. What may cause this problem? ingberto@hotmail.com With...
The words "Demo Stop/Clear" are right there on the left-hand control knob.
http://www.p4c.philips.com/files/f/fw-c788_19/fw-c788_19_dfu_eng.pdf
Page 13...
To activate the demonstration
 In Standby mode, press and hold DEMO
STOPçon the system until "DEMO ON" is
displayed.
?žœ The demonstration will begin.
To deactivate the demonstration
 Press and hold DEMO STOP çon the system
until "DEMO OFF" is displayed.
?žœ The system will switch to Standby mode.
Note:
- Even if you remove the AC power cord and
reconnect it to the wall socket, the demonstration
will remain off until you activate it again.
Jan 22, 2011 | Philips FWC788 CD Shelf System
Can I connect a blu-ray player to the hometheatre system?
Technically, yes but not so it would yield BD-quality audio or video. You need a control receiver that accepts either HDMI/DVI INPUT for 720I and above video. The digital audio in will probably suffice.
Jun 14, 2010 | Philips HTS-3555 System
SA HE200 ~ Overload at power up
First of, be sure volume is turned all the way down before or as you are powering it it.
Second if that does not work disconnect all speaker, and input/outputs.  Power the device on and see if it says overload.
If it does skip the rest of these steps, your capacitors are bad or the power supply is no longer functioning correctly.
If it doesnt, start with testing each speaker at power up.  Match the speaker to the output it goes on, power the device see if it says it.
If it does on any speaker test it is a speaker issue or a terminal issue.  To test for terminal or speaker issue plug a different/ known to work speaker in that same terminal, if it doesnt say overload it is a speaker issue, if it does say overload it is a terminal issue.
Once you have made sure all speakers and terminals work correctly start plugging input and outputs in and test individually.
Jan 09, 2009 | Panasonic SA-HE200 Receiver
I have a philips tv and a xbox 360. I cannot get the xbox to work with this tv. The xbox is pluged in to the tv and I know the yellow white red cords work because they work when i use the vcr. It was...
I guess when I moved the xbox i hit the swith for the hd and regular tv. It's on the back of the xbox next to the power cord plug in. I could hear sound but i couldnt see the screen. When I swithched it to TV the picture came on.
Jun 01, 2008 | Philips Televison & Video
Excalibur works fine one day than not the next...
sounds like some loose solder joints. check power output with external meter to see if output is ok . i think youprobably have 2sc1969 finals init unles someone has changed them theyshould put about 25 watts if tuned correctly. also check the antenna a and antenna b switch to see if something has shorted across it inside cabinet.
Mar 16, 2008 | Radio Communications
Philips DS9000 Primo Speaker Dock for iPod/iPhone Logo
18 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
