Question about Coleman GolfCat Perfectemp Catalytic Propane Heater
Brand new coleman golfcat catalytic propane heater will not start.
New propane bottle and I can hear the gas hiss when I turn it on. I have tried 2 batteriesbut no spark or fire.
Therinnaiguy
  • 1420 Answers
SOURCE: No Gas in Heating Element
If you are using the heater at temperatures below 40 degrees, ther will not be enough gas vapor to run the heater. If the temperature is above 40, look for an obstruction in the gas piping or gas valve itself. There is a small screen on the inlet side of the gas valve that you can inspect if you remove the inlet hose. Make sure you reinstall the hose using a teflon base pipe sealant on the threads.
Posted on Dec 19, 2007
  • 211 Answers
SOURCE: looking for owners manual for coleman powermate 4000
Hi
First you need to change the plug with a new one with the same heat range(too long time).Priming the engine few times(put some gas in the cilinder through the plug hole)and start the engine until it runs constantly.
bestregards savumihai71
Posted on Feb 12, 2009
  • 11 Answers
SOURCE: Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Posted on Mar 21, 2009
lsteward68
  • 331 Answers
SOURCE: No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Posted on Jun 05, 2009
  • 193 Answers
SOURCE: heating problem
inside its a sensor or limit thats shutting it off
Posted on Jan 25, 2010
Bad propane gas bottle - is it possible to get bad gas in new propane bottles?
The supplier's bulk propane tank either is not equipped with a moisture filter in the discharge line or the filter is ineffective.
Feb 06, 2017 | Heating & Cooling
Gas is on can hear ignition. Doesn't light. May not have gas to heater. Air in line?
Check also to see if the valve on the gas valve itself is in the "ON" position. Is it on or off?
If it is on, then you may in fact have air in the gas line that needs to be purged.
BE CAREFUL WHEN PERFORMING THESE STEPS!! ESPECIALLY IF PROPANE GAS - LPG!!!!!!
Have a large piece of cardboard or the front cover/door of your heater will suffice.
If solid pipe to heater, then there is a union, if you have flexible gas line to heater then you have a flare nut.
With NO flames or sparks even close - NO SMOKING !!!Carefully & slowly loosen either the union or the flare nut with gas valve open. You will hear hissing sound. Leave open for about 30 seconds, until you smell the gas. Carefully & slowly tighten either the union or the flare. Take the cardboard or door, and fan towards the heater to push away and fan away any gas fumes. Do this for about a minute or so. Very Important you do this, again especially if Propane. Propane is a very heavy gas & it will linger in a "Puddle", unseen puddle near the heater. If you did not fan away these fumes, when the heater starts to ignite - .... not so pretty.
Anyway, if you had air in line, heater should fire. If it didn't try above steps one more time. If it still does not fire, possible bad gas valve.
Dec 16, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Feb 07, 2011 | Coleman Heating & Cooling
The pilot light ignights but as soon as I let the knob out to light the heater the pilot goes out. I also noticed that when I depress the pilot knob I can not hear the gas coming out like I use too. I have...
i suggest you change thermocouple on heater it is the pilot control, firstly i would find where it attach's to valve and make sure it is screwed into valve properly (do not over tighten). If the pilot still doesn't go change the thermopile and if that don't work change the valve, but it most likely the thermocouple
Nov 22, 2010 | Coleman (5040B750) Patio Heater
I have had two small Coleman 'Frontier PZ' propane lanterns for a number of years with no problems. Last year one of them started shutting down for no apparent reason - it would light normally, burn for 4...
there is something in the jets or the piping to the mantels, you my find spider webing there, if you did no cap the port where the tank goes some small friends might have wanted to go camping with you.
Apr 04, 2017 | Coleman 10' X 10' Sundome Tent 9160K101
Have three coleman hws same problem on last weekend. Fully charged batteries 6.45volts. New gas bottles. Turn unit on water starts to run gas ignites for one to two seconds and then goes out water will...
It will probably be one of two issues. Either the waterflow sensor is not working correctly or the propane valve connected to to control knob is stuck shut. The water flow sensor is located on the side of the copper element (grey box) check that it spins easily. The propane valve is attached to the control knob by a long metal wire and should turn freely as you turn the control knob to warm
Jun 21, 2010 | Coleman Hot Water On Demand
How do i light this gas grill, it is a charbroil quantum....it was borrowed from our friend, who is now not picking up the phone...
Checklist:
1-Make sure propane tank has propane in it.
2-Turn regulator (valve attached to propane tank) on.
3-Turn burner dials on, usually there is a "light" or "ignite" position to let the most gas flow to start. If there isn't, just turn it/them to high.
4-Listen for the hissing, if you hear some hissing from the grill, it has gas flow.
5-Turn the dials back off and give 3-5 minutes for gas to clear.
6-Turn dials back on and hit the igniter button.
That should do it! :)
Sep 22, 2009 | Grilling
Napoleon PTH10PSS Infra-Red Patio Heater
If you have a piezo ignition, then all you will hear is one click when you turn the knob. If I am guessing correctly, when you push in the knob and turn it, the gas flows to the pilot assembly, when you turn the knob far enough it will clilck and that sends the spark to the pilot assembly to light the pilot. Try turning the knob slowly before you get to the click, that will allow more gas to flow to the pilot. If this does not work, then you may have a blockage in the pilot.
Jun 29, 2009 | Napoleon PTH10PSS Infra-Red Patio Heater
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Coleman GolfCat Perfectemp Catalytic Propane Heater Logo
57 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
