Question about Intertherm 56000 Btu Gas Furnace
After preheat the fan cuts in for 10 sec then cuts out, cuts in for 15 sec, then cuts out. this continues to longer interviles. I have replaced computer box twice and have spent hundreds and problem
When I urn the power off to furnace for 5 sec I here a click, That's when I turn power back on. Flip fan switch to manual and it always runs.
    Genius:
  • 1,198 Answers
Try Googling the problem. Who have you paid so far, someone from the gas company, or a private technician? Was the technician from an Intertherm dealer? I would think a dealer would have qualified techs.
Posted on Nov 27, 2013
Why does my fan stay running for more then 90 minutes until the battery goes dead
Radiator fan runs continuously - volvoXC.com
www.volvoxc.com > Forum > The Vehicles > 2001-2007 XC70 (V70XC)
Jul 12, 2011 - 10 posts - ‎6 authors Hi, I have a problem with the radiator fan running continuously. ... According to Volvomechanic, when the pressure in the aircon gas goes ... 2002 xc70 cooling fan stays on
Jul 15, 2012
Blower Motor stays on.
Jan 15, 2011
fan after cutting off ignition?
Jul 25, 2004
More results from www.volvoxc.com
Oct 20, 2015 | Volvo S80 02 2002
Oven kicks on gas lights runs for 10 sec then beeps showing preheat is done then kicks off
I had to replace my igniter to get mine to work. I did it myself for $65.00 Mine the gas just would not stay on to heat up.
Mar 13, 2015 | Maytag Ovens
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Model IWL12 is showing "Power Cut restart in 10 secs" what is wrong.
Your motor controller board has faulty power supply,
Board needs replacing.
Dec 17, 2012 | Fisher and Paykel IWL12 Top Load Washer
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
Freezer compartment no longer cools. Continuous defrost cycle?
Good day,
Sounds more like the compressor trying to start and can't.
Pull the machine out, remove the rear cover and see if in fact the sound is coming from the compressor.
Apr 08, 2010 | Whirlpool Refrigerators
Intermittent fan motor & relay switch (4-5 sec.) - warm freezer
you need a new overload contactor or they call them an RTX also that powers the compressor it is located on the compressor body,also replace the capacitor that plugs into the RTX at the same time you replace the RTX that will solve your problem
Dec 24, 2009 | GE Refrigerators
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Fan continues to run after desired heat is established , I blew out the line at pilot and the unit is taking 10 to 15 mins for fan to cut off
Looks like your fan limit switch may be bad. It fits into the warm air side of the furnace. It tells the fan to come one and off when the heat is blowing over the limit switch. Now if that limit is defective it also will affect the lighting of your heater being it electronic ig-niter or just common thermocouple type controlled pilot light. Now above your post I think the wong information was given about your gas heater, so giving you the exact information will be difficult. Now from hearing you explanation of the problems, I hope my information was a help to you, Thanks Sea Breeze
Oct 26, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Intertherm 56000 Btu Gas Furnace Logo
134 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
