Question about Ricoh Aficio 1027 All-In-One Laser Printer
The stop key was pressed on the Ricoh fax machine and now everything is frozen how do I fix this?
3 Suggested Answers
  • 566 Answers
SOURCE: How do I delete stored faxed numbers (speed keys)
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Posted on Jul 29, 2009
canontech
  • 1219 Answers
SOURCE: how do you fix the scewing on a aflico ricoh 1018
replace the press.roller bushings,or get rid of moisture in paper on increase fixing temp.
Posted on Jan 13, 2010
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Office Equipment & Supplies
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Our Ricoh 1800l has stopped recieving faxes how do I fix this?
our Ricoh 1800l has stopped recieving faxes how do I fix this
Feb 15, 2011 | Ricoh SFX2000M Plain Paper Laser Fax
Fax Machines Ricoh Fax 4430NF error 0550H "call
Easy !
Press yellow button
Enter numbers: 107
Push red button for 5 seconds
Press number: 1
Enter: 5#810#
Press number: 1
Press (Half)tone and OK button at the same time for some seconds.
DONE ! Greet Barry
Feb 01, 2011 | Ricoh 4430NF Laser Fax
How do you set the time on a ricoh fax 2050l
PRESS (FUNCTION)
PRESS (6)
ENTER (2222)
ENTER(91)
ENTER(YES)
CHANGE MONTH WITH (*) OR(#) KEYS
PRESS (I>) CURSOR RIGHT KEY TO MOVE CURSOR
CHANGE DATE WITH WITH KEYPAD
CHANGE AM/PM WITH (*) OR (#)
WHEN DONE PRESS (YES) THEN (FUNCTION)
Hope this helps
Nov 20, 2009 | Ricoh 2050L Laser Fax
Time on the clock is incorrect
Press [User Tools] key. Press < or > until "2.Fax Features" is displayed. Press [OK] key. Press < or > until "3.Setup" is displayed. Press [OK] key.
Press < or > until "3.Date/Time" is displayed. Press [OK] key several times to step through to time setting. Set correct time with number keys. Press [OK] key. Press [User Tools] key to return to standby mode. Reference page 60 in the Advanced Features manual.
Nov 20, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Fax confirmation with copy of 1st page
what is the error code 05 for ricoh fax 1140L?
Jul 21, 2009 | Ricoh FAX1180L Laser Fax
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
How do you change the date and time on a Ricoh 3800L fax machine?
To change the date and time on a Ricoh 3800L:
Press the Function key, 6222291, Yes. When the date appears, use the asterisk (*) and pound sign (#) to change the month and to change AM or PM, and use the keypad to change the date, month, and time.
Press Yes Function when you've got it set and want to save it.
Dec 23, 2008 | Ricoh FAX3800L Plain Paper Laser
Clear a Ricoh Fax 2000G Memory
    1. If your documents have already been scanned into memory:
    2. touch the [Change/Stop TX File] key
    • check that the [Stop Transmission] key is selected
    • touch the file that you want to stop, then touch the [Stop Transmission] key in the confirmation dialog box
    • touch [Exit] to return to the Fax Mode display
    1. If your documents are being transmitted:
    2. press the red [Clear/Stop] key
Dec 22, 2008 | Ricoh 2050L Laser Fax
Ricoh Aficio 1027 All-In-One Laser Printer Logo
23 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
