Question about LG 42LD450 42 in TV
Broke my cable connector on back of tv Model 42ld450
  • The Knight
    The Knight Nov 26, 2013
    Hi Vikki Silva, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Do you mean that the damaged cable is one that connected to panel to its T'Con board? Provide some more details.
Cable end broke on tv
You will need to open up the tv and re-solder the F connector back on the board it fell off of.
Mar 16, 2014 | Proscan Televison & Video
I was moving the tv and forgot to unplug the cable and the connector in the back of the tv broke off. What can I do?
You will have to replace the board that the connector is on. You did not give a make and model so I can not give more information.
Mar 11, 2011 | Televison & Video
How do i find my sky remote code for my tv lg 42ld450
google your remote model and search code list and look for your tv brand
Jan 07, 2011 | LG 42LD450 42 in TV
Sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
May 24, 2010 | LG 42LD450 42 in TV
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Main cable connector broke off back of TV
Maybe so. Sometimes the connector is fed by an RCA connector which just plugs in inside the TV and sometimes it needs a little solder work. Sometimes you have to solder on the circuit board and if it's a multi-layer board you want an expert to do it but from the manual it doesn't look like that is the case with your TV.
I'm pretty sure Radio Shack stocks such connectors with maybe a little hardware to get the fit right.
Dec 17, 2008 | Televison & Video
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
LG 42LD450 42 in TV Logo
Computer Repairing
Computer Repairing
