Question about NEC-Mitsubishi NEC Display Solutions LCD2080UX + (White) 20.1" LCD Monitor
Screen goes blank after a few seconds
After a few seconds the nec lcd 2080 sceen goes blank and will not come back till turned off for a while
    Guru:
  • NEC-Mitsubishi Master
  • 829 Answers
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
Posted on May 10, 2009
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
DiamondPoint V71LCD Not displaying image
The LCD screen may be burned out. There's whats called an invertor board and there is an electronic ribbon strip on the LCD itself. If you look very carefully you can probably see a faint image on the screen. The LCD screen will need replacing. Before doing anything with this monitor, try it on another computer first and if you can try another monitor on your computer. Other than that, there really is nothing you can do but replace the monitor.
Jun 27, 2007 | NEC-Mitsubishi Nec Display Solutions...
NEC-Mitsubishi NEC Display Solutions LCD2080UX + (White) 20.1" LCD Monitor Logo
873 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
mukhtar21 shaikh
mukhtar21 shaikh
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
