Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool model#ed25texhw03 will not keep cool both side stopped getting cool clean coil front and back fan still blowing what may be problem
  • 32 Answers
This could be a problem with the compressor.
When a compressor won't start and “clicks,” this indicates it (the compressor) is locked up and cannot start so it clicks off on an overload thermal (temperature) protector. If the compressor only runs for a short time then clicks off it is likely drawing too much amperage, overheating and cutting off on the overload protector. Nothing other than replacement can be done with a compressor that is locked up or drawing too much amperage as it is a problem with the internal components of the compressor.
It is absolutely crucial that the condenser coils are clean and the condenser fan motor, if there is one, operates properly or the compressor will overheat and go off on the overload protector. This handy condenser brush makes cleaning your refrigerator condenser coils a snap.
The compressor can be replaced but this is very expensive ($400- $500 parts & labor) due to the fact that the refrigerant needs to be reclaimed from the system and the compressor refrigerant lines unsoldered, new lines soldered on and new refrigerant charged into the system. This is something only a trained and licensed repair person can do. Compressors are part of the "sealed refrigerant system", many manufacturers warranty the components of this system for an extended period of time, usually 5 years from the purchase date.
Go here for: Whirlpool-Refrigerator-Parts
RepairClinic.com
appliance parts, help & more
Posted on May 08, 2009
I have a Whirlpool gold conquest side by side model GS5SHAXNL00 that has a clicking noise coming from the rear. The freezer isn't keeping things frozen but the fridge side is nice and cold. I can hear the...
These models have two fans. One is located inside the unit. The fan inside blows air across the cooling coils. With the door open this fan is usually running other than defrost cycle. If this fan has stopped it will cause the compressor to overheat and the relay will cycle.
The second fan equally as important is located under a fiberboard cover accessible from the back of the unit at the bottom. This fan is usually noticeable by an air flow sound. Usually air flow is detectable out of the front grill. If this fan fails to operate, blocked due to a major build up of lint the compressor will overheat and cycle as you hear,
Hope this helps?
This is the fan inside the freezer.
Jun 25, 2017 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
Whirpool side by side refrigerator hot door gasket
Good day,
The first step is to clean the coils properly. Remove the back cover, and make sure the cooling fan is running. At this point, unplug the machine and with a wand and a push pull vaccuum blow the dirt out of the coils from back to front.
Yes , it's filthy and ugly, but the only proper way yo clean it.
Make sure the cover in the back is properly reinstalled. (See my tips). At the beginning, the divider will be fairly hot, but should slowly cool after enough running time to get the machine to it's normal temperature.
Apr 30, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Maytacg dual cool refergeration
wherever you can access the condenser side closest to the fan is the best place because you want to blow compressed air through the coils from the side where the fan is located as that is the side where the air is sucked in through the coil assembly. you want to blow the dirt out in the opposite direction of the normal air flow through the coil fins.
Mar 13, 2010 | Maytag Energy Star Side by Side...
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Center of side by side very hot center between doors very hot whirlpool 25 cu. ft
If by the center bar, you mean the divider between the freezer and fridge sections, then the heat you're feeling is the built-in condensation heaters designed to keep moisture from forming on the exterior of the unit. These heaters also help to keep moisture from freezing on the inside of the door edges and in between the sides of the unit as well.
It's a normal function of modern, frost-free refridgerators, Some brands/models have an "energy saver" switch inside the fridge section that you can use to turn off the extra edge heaters, if you aren't experiencing excessive condensation forming on the outside of the unit.
Not all the heaters can be turned off even with fridges that have an energy saver switch, as the manufacturers engineer/determine where and how many edge heaters are needed to get the best performance out of their products.
With an energy saver switch, you turn it "ON" to actually turn off the surface heaters, and turn it "OFF" to have the heaters run constantly. Thus having it "ON" saves the energy that would be used to keep the heaters very warm. Some manufacturers have added electronic sensors to regulate these heaters, but not all makers have done this.
You should also clean the coils to help the fridge run better. As far as getting to the coils to clean them, if you have a long narrow crevice tool with your vaccum, you can try to use that to get underneath the unit to carefully get the dust out. I found that if you move the unit out where you can get to all sides, makes it easier to remove any dust on the back and underside of the fridge. Don't foget that you might have to remove the lower, back access panel to get at the compressor/coil assembly.
Just unplug the fridge first to keep from ruining your spouse's vaccum tool in the cooling fan blade, like I did once and never he-ad the end of it! (Not to mention the noise it makes - brought her running to see what I was doing!)
If that isn't possible, you can always use the blower end of a vaccum to blow out the coils, but it's a messy proposition at best. I've used a swiffer taped with some duct tape onto a long, thin dowel to get quite a bit of the dust the vac couldn't $uck out - I prefer that to blowing dust out as it's less messy.
Provided your fridge and freezer are cooling properly, you shouldn't have any issues with the warm center compartment divider causing you any problems.
Hope you find this Very Helpful and best regards!
Sep 17, 2009 | Whirlpool Refrigerators
Compressor cooling fan not running. Found problem based on diagnosis of strip between freezer and refrigerator being hot. How do I get the fan running?
You will have to replace the fan motor . Maybe you can turn the blade by hand to get it started . If not , try putting a small fan blowing on compressor towards front , so it will help keep the coils cool also , until you can get a new motor . If you had given model number , I could have given you the part number .
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5PHE side-by-side refrigerator's center panel is HOT (not warm). Do not think fan is blowing. Already cleaned out coils as best I could with a pointy bristle brush made for it (Still can't get...
I have this same issue. The fan is not working properly. On the back bottom right of the unit is where the fan is located. Take off the card board panel and the fan is right there. Just by taping the fan with a screw driver the fan started running again (and the center cooled down quickly). It worked fine for a month, but has stopped again. I am going to replace the motor, hopefully that will solve the issue.
Apr 28, 2009 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
248 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
