Question about Ryobi Ry09050 26cc 200mph Gas Handheld Leaf Blower/vac
Ryobi leaf blower vac won't start
When pulling start cord, the engine will not start. Tried to clean the plug & starter fluid, but still won't start. there is gas in the primer "bubble."
  • 272 Answers
SOURCE: Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
Posted on May 12, 2009
  • 9 Answers
SOURCE: My ryobi will start but dies about 5 minutes later
Try running the machine with the gas cap loose. There could be pressure builiding up in the system due to the cap being too tight. There is no vent on these systems like an automobile. If the gas cap is overtightened this could be your problem as the cap is equipped with a gasket that allows the vapor to vent through the cap. Overtightening could be sealing off your vent
Posted on Jun 06, 2009
  • 148 Answers
SOURCE: Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Posted on Jul 13, 2009
  • 4 Answers
SOURCE: My Ryobi RBL30MVA. leaf blower will not start,
I have had this exact same problem with the same model after just one hours use.
Returned it a week later and after 2 months the replacement did the same thing.
Returned that one and got a third. A week later that ones doing the same thing again after only an hour or so use.
Obviously some defect in them.
I'll be getting my money back and visiting the local mower center to get their help rather than doing the guess work my self and ending up with a dodgy model
Posted on Dec 24, 2009
2strokeguy
  • 183 Answers
SOURCE: what is the gas oil
Most Ryobi products made in the past 5 years use a 50:1 fuel mix. Check the fuel cap to see if it is listed there. The older Ryobi product used a 32: 1 fuel mix ratio and it was usually listed on the sticker that shows you how to work the choke. If in doubt, go with the 32:1 ratio. The only thing it will cause is premature fouling of the spark plug. Too little oil in the mix will cause premature engine wear.
50:1 is 2.6 ounces of 2 cycle mix to each gallon (U.S.) of gasoline.
32:1 is 4.0 ounces of 2 cycle mix per gallon.
I recommend to use a 2 cycle mix that is specifically designed for lawn equipment and contains fuel stabilizer. The ones with stabilizer will usually be .5 ounces larger.
Posted on Nov 30, 2010
I have a factory refurbished Ryobi ZR08510 blower/vac from the factory. I cannot get it started. What should I try first?
Hi Paul:
I'd start by pulling the spark plug, attaching it to the lead, then spin it over and check for spark.
This will probably be a 2 cycle motor (Check to confirm) so make sure your fuel is mixed correctly.
Dec 30, 2015 | Ryobi Blower Vac 205mph Leaf Blower Or...
How to start ryobi leaf blower model 09050 i tried everything i primed it with gas tried shooting starter fluid in it
Do you have a spark on the plug? Did you use gas-ethanol mix?
Use premium only.
Sep 12, 2015 | Ryobi Garden
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Pull cord for starter is not catching?
There are starter pawls that catch the flywheel when the rope is pulled. They are plastic. You will need to disassemble the unit and remove the starter assembly to inspect the pawls.
Nov 11, 2012 | Ryobi Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Trimmer won't stay running without starter fluid
drain any old gas/fuel mixture out of unit.
purchase new gas and mix with oil as recommended for your engine.
clean the air filter on the unit.
pull the spark plug and clean with carb spray and reinstall...
you also may need to remove the carb and clean any jets with carb spray... old gas can turn into a shellac'ish type goo and foul up the works...
I recommend draining all fuel after usage...
May 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
May 12, 2009 | Ryobi Backpack Blower 25.4cc
Leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Oct 31, 2008 | Homelite 'Yard Broom' Leaf Blower
Ryobi Ry09050 26cc 200mph Gas Handheld Leaf Blower/vac Logo
188 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
