Need a power cord for electic thermo pot NC-EH40P
4 Suggested Answers
yalmer
  • 549 Answers
SOURCE: Replacement Power Cord
They may have it here
www.cablewholesale.com
phone: 888-212-8295
Posted on Feb 09, 2008
  • 351 Answers
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the pot with you to make sure you are getting the correct cord.
Posted on May 07, 2010
  • 1140 Answers
SOURCE: Is it possible to replace a wire ? to my my thermo pot model NC -30 HN. The thermo pot is working the wire is loose I need a new wire
I did an online search. I could not find a cord for your pot.
Posted on Oct 17, 2015
I replaced the exhaust motor on my p24fs breckwell stove. In doing so i had to dis-assemble most of the parts. The thermo discs mounted to the flange of the exhaust motor were shot, due to the heat/ years....
They are safety devices, the same configuration, and are NC. If this area gets too hot, they open to prevent further damage and possibly fire.
Jan 28, 2011 | Heating & Cooling
It seems to be perking correctly but stops and then starts to perk again and again, this continued until I unplugged it, and also the light to indicate it was done never came on
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold The problem is the keep warm element. The reason, your pot perk's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. Thanks and please ask if you need more help. Go to repairshack.com for the part. Ron
Sep 25, 2010 | Faberware 10-22 Cup Coffee Urn
The first problem we noticed is the coffee is not as hot as it used to be, but it was still strong enough. Now the unit perks for about 10 min for a full pot, the light comes on....but the coffe is weak...
Hi, The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix. Thanks and please ask if you need more help. Ron For the part go to repairshack.com
Aug 17, 2010 | Faberware 10-22 Cup Coffee Urn
Percolator not working
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers.O eBay the KW element is $8.00 and $2.00 S/H. You can BUY-IT-NOW with this auction. Thanks and please ask if you need more help.
Mar 07, 2010 | Salton Farberware& Percolator
My perc used to work great, then it went downhill. I clean it and we were right back to good coffee ... but now it has gone to making weak, barely warm coffee and the pot isn't dirty at all. I need a real...
Hi First
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. callahanronald@att.net good luck. Ron
Jan 07, 2010 | Faberware Coffee Makers & Espresso...
Dec 28, 2008 | Le Chef Electric Shabbos Hot Water...
phone: 888-212-8295
Jan 30, 2008 | Kitchen Appliances - Others
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
