Question about Coby MID7065-8 7" Android 4.0 Tablet; 1.2GHz Dual Core Processor, 1GB RAM, 8GB Internal Storage, microSD Card Slot, 1024x600 Resolution, Capacitive Touchscreen, 0.3MP Webcam, HDMI Port, Google Play Support & USB OTG Compatible
Tablet has a mind of its own
When I turn the tablet on and unlock the screen, it starts selecting things on its own. It will open apps and then go back to home screen and open another one all with out touching the tablet.I have tried to turn it off and back on the only thing I have not tried yet is a factory reset.
  • 76 Answers
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Posted on Feb 28, 2011
jmernst
SOURCE: my coby kyros mid 1125 want unlock when i try to slide the unlock slider nothing i've tried to power down it want let me do nothing help please!!!!
Have you tried taking the battery out? That solves a lot of problems.
Posted on Dec 27, 2011
SOURCE: The tablet turns on but seems frozen and shows the android screen and nothing else. Tried to reset it but it does the same thing
so wat do i do
Posted on Dec 28, 2011
humnath_paud
SOURCE: can not unlock my coby tablet
I forget unlock password
Posted on Dec 03, 2012
  • 52 Answers
SOURCE: MID 7065 wont connect
try to update firmware or install custome firmware
Posted on Dec 17, 2013
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
Jul 22, 2016 | Polaroid 7-in. Internet Tablet - Other
Hi my tablet will not upload videos to Facebook using the app, only photos, but going to the website works okay?
Android or iOS? The first thing I suggest is going to setting > apps > scroll down to Facebook > click on "storage" > and click on CLEAR CACHE (not data.) Then restart your tablet. Keep in mind that uploading videos can take a very long time although you may have a speedy upstream and this may not be an issue.
You can share videos with Facebook without using the app though. Go to your gallery and select the video > share button in upper right hand corner > select Facebook. You can do this with pics and documents too.
Jul 01, 2016 | Facebook Computers & Internet
How can I reset acer tablet A500? and restart it?
To help you perform a hardware reset, please follow the steps mentioned below:
- Holding Volume Up, Turn on Power, then switch Lock On/Off back and forth with Volume Up continually held. This starts the Reset, wait for 20 sec to start Android.
If that fails to reset the tablet, please follow the next steps as mentioned below:
- Power on the A500.
- Use a small, thin object, such as a paperclip, to press the recessed reset button located on the bottom of the tablet.
- If done correctly, the tablet will power off and restart.
- Once the tablet is back at the login screen, repeat this procedure again.
If you want to perform a factory data reset, please follow the steps mentioned below:
- Select Apps, Settings, and then Privacy.
- Select 'Factory Data Reset' and then select 'Reset Tablet'.
- Select 'Erase Everything' to format your tablet back to factory default configuration.
GuruAid.com
Jun 29, 2016 | Acer Computers & Internet
My sister locked his tablet with a password and now he cant remember what the unlock code is. its the type of code you unlock by making a pattern with your finger.
You have to reset it to factory default just follow those steps:
1. shutdown the tablette
2. hold volume up button and press the power button
3. when manufacturer logo come realise the power button but keep hloding the volume button to get into recovery mode
4. in recovery mode use volume up/down button to navigate and the power button to select
5. choose WIPE DATA / FACTORY RESET than select YES .... wait a moment then select WIPE CACHE PARTITION
6. finale step select REBOOT
keep in your mind the all data in the phone will be erased (apps & games)
ALL DONE!!!!
Mar 05, 2015 | Proscan 7-Inch Android Internet Tablet,...
ALL DONE!!!!
Why does my Telstra 4g tablet keep turning off
Take it to service center or flash it yourself with fresh ROM
Aug 08, 2014 | Sierra Wireless Unlocked Telstra 308 4g...
How to unlock proscan android tablet plt8015-k-b
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
Jun 30, 2014 | Proscan Recertified - PLT7035 4GB NAND...
NEED SCREEN UNLOCK CODE FOR ACER ICONIA 200 TABLET
Well, the only way to unlock your tablet is to factory reset tablet.
To reset tablet start the tablet, then hold volume up then select factory reset.
Sep 15, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
My EM543 tablet will turn on, the word tablet "Tablet" comes up with a rotating circle underneath it . Cannot open the tablet.
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
Reset Factory from safe mode android, watch video in my blog
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Dec 26, 2012 | Tablets & eReaders
Coby MID7065-8 7" Android 4.0 Tablet; 1.2GHz Dual Core Processor, 1GB RAM, 8GB Internal Storage, microSD Card Slot, 1024x600 Resolution, Capacitive Touchscreen, 0.3MP Webcam, HDMI Port, Google Play Support & USB OTG Compatible Logo
Top Coby Computers & Internet Experts
shadowchb
rey francis basa
rey francis basa
Are you a Coby Computer and Internet Expert? Answer questions, earn points and help others
