Pwb-0656-02 - Televison & Video
I have a Kyocera FS-4000DN Ecosys. I replaced the toner and now I get this. error 7410:0106690. Does anybody know what this means?
7410 Drum unit non- installing error The drum unit is not installed or not installed properly. The drum PWB EEPROM does not communicate normally. The drum unit is not installed. Install the drum unit (See page P.1-5-10). Defective connection drum PWB (YC1) and connect-L PWB (YC3). Check the connection of connectors drum PWB (YC1) and connect-L PWB (YC3). (See page P.1-4-9, refer to figure 1-4-5) Defective drum PWB EEPROM. Replace the drum unit (See page P.1-5-10). Defective engine PWB. Replace the engine PWB
May 26, 2015 | Kyocera Office Equipment & Supplies
What is the error code e7-80 on a Sharp ar-m450u ?
E7-80 MFP-SCU PWB communication error
Cause
SCU PWB connector connection trouble.
SCU PWB - MFP PWB connection trouble.
SCU PWB mother board connection trouble.
SCU PWB trouble.
MFP PWB trouble.
Mother board trouble.
Check & Remedy
Check connection of the SCU PWB, the MFP PWB,
and the mother board.
Check the ground.
Replace the SCU PWB.
Replace the MFP PWB.
Replace the mother board.
Mar 10, 2015 | Sharp Office Equipment & Supplies
MX 351U SHOWING E7-90 ERROR CODE WHAT THE SOLUTION
This is a PCU PCB Communication error. 9 times out of ten it will reset by simply switching the machine off and then on again. If the problem persists here is the section from the manual that describes the possible causes and remedies.
E7-90
MFP - PCU PWB communication error
Trouble content
Detail
MFP
Cause
PCU PWB connector connection trouble. PCU PWB - MFP PWB connection trouble. PCU PWB trouble.
MFP PWB trouble.
Check & Remedy
Check connection of the PCU PWB, the MFP PWB, and the mother board.
Check the ground.
Replace the PCU PWB.
Replace the MFP PWB. Replace the mother board.
I hope this helps
Good Luck
Follow me on Twitter @CDOS_Service
Jan 14, 2014 | Sharp Office Equipment & Supplies
C6400 error problem of kyocera printer
C6400
Contents: Zero-crossing signal problem
• The engine PWB does not detect the zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes: Poor contact in the connector terminals.
Check procedures/corrective measures: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Causes: Defective power supply PWB.
Check procedures/corrective measures: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Dec 17, 2010 | Kyocera FS-1118MFP Laser Printer
Dear...i have kyocera printer FS2000D and error code 7410:233769... Can somebady give me some advice what can i do....Thanks in advance
installed properly.
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Oct 05, 2010 | Kyocera FS-2000D Laser Printer
My kyocera km1820 displays error code c6400
specified below.
At power-on: 3 s
Others: 5 s
Causes:
- Poor contact in the connector terminals.
- Defective power supply PWB.
- Check the connection of connectors YC7
necessary.
- Check if the zero-crossing signal is output
- Replace the engine PWB if C6400 is detected
Sep 24, 2010 | Kyocera Copystar CS-1820 Black and White...
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
installed properly.
normally.
Causes:
Aug 04, 2010 | Kyocera FS-4000DN Laser Printer
Kyocera fs 9530 - f040 error
this error came because of the Defective harness between engine PWB and main PWB or improper connector insertion. open both board and re fix it and check ....... please mention your correct printer model in next comment so we will give you idea how to open the boards ....... restart your printer and check it ...........
Main - Engine controller PWBs communication
error
• The communication breakdown occurred
between main controller PWB
and engine controller PWB during 30
seconds.
cause
Defective engine controller PWB........Defective main controller PWB.
solution
Replace the engine controller PWB
Replace the main controller PWB
Dec 21, 2009 | Kyocera FS-2000D Laser Printer
Error code
fuser has oevr heated - needs resestting or replacing
Mar 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-m162
E1 00 Content IMC PWB communication trouble.
Detail An abnormality occurs in communication between the MCU PWB and the I
MC PWB.
Cause IMC PWB-MCU PWB harness abnormality.
MCU PWB connector disconnection.
IMC PWB ROM defect/data abnormality.
Check and remedy
1. Check connection of the connector and the harness between the IMC PWB and
the MCU PWB.
2. Check the ROM of the IMC PWB.
Feb 12, 2009 | Sharp AR-M162 All-In-One Laser Printer
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
