Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Remote valves not working.you can raise frontend loader but it want come down. also the bucket want work . change all hyd fittings.and check pump pressure thats good. need help.
    Genius:
  • 1,198 Answers
Change the filter. If you can lower the loader by loosening a line at the valve, suspect the valve. All lines usually dump to tank at the valve. Make sure that line is ok. If any valves are electric, suspect them even more.
Posted on Nov 26, 2013
Testimonial: "I change the filter also took two remote valves from another tractor. not saying there good but same problem. going to check hyd lines next. thanks for the info. ill give you a update soon."
3 Suggested Answers
  • 20 Answers
SOURCE: Farmall 560 hydrolics wont work on the bucket
make sur you dont have lines switched. check fluid levels and lastly check th pump for week lobes
Posted on Jan 18, 2013
SOURCE: Case IH DX29 Hydraulic prob. bucket wont lift
Check control cable from lever to valve to see if it has broken or seized
Posted on May 08, 2012
Hyraulic stops working while running
sounds like your control valve body going into bypass, replace the filter first, then check to see if there is a safety catch not working, some outriggers have switches on then to prevent bucket movement if they are not fully extended.
Mar 02, 2015 | Garden
No fluid from rear pump 410 john deere backhoe
1st ck hyd tank for fluid level and fluid quality 2nd remove and ck hyd filter for blockage (note some hyd filters have a water sensing block valve inside) 3 rd verify that fluid is reaching pump , pumps will make horrible noises with no fluid in them , if all are well replace pump , and ck that bypass valve is not stuck open and is set correctly (some are internal to pump )
a method i've been sucessful with is to temp power hyd system with remote from another working tractor/bobcat , this sometimes unsticks bypass valves , but unless your familiar with what fittings do what and such I don't recomend this action for novices
Mar 19, 2014 | John Deere Garden
May 08, 2012 | Farmall Toys
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
Accumulator charging valve
This sound weird but the small pump on the back of your steering pump is the brake and pilot system supply. It is the possible source of your problem. Check for flow from the pump. At low idle there may be low flow.
Jun 19, 2009 | Caterpillar American Construction...
My hydraulic pump lifts actuators up and down.
With NO PREASURE on the hyd system or the cylinder ( brace it )unhook both hoses from the hyd cylinder and hook together ( may require a made up hose or special fitting ), then operate the system again. If it bogs down again you KNOW it's not a cylinder problem ( piston dammage, bent rod, piece of metal stuck in a cylinder port...) . With the hoses hooked up normaly, you possiably have a restriction on the rod side ( pressure down to the cylinder) of the control valve. I have seen a piece of piston stuck in the port fitting because it could not go by the spool. Or depending on allot of variables, you MAY have a " flow control valve " that will control the decent speed of the cylinder failing or out of adjustment ( fixed orficed check valve or manual gate ). these are normally in the barrel line of the cylinder, but that depends on the configuration of the cylinder.Good luck and be carefull!!!
May 18, 2009 | Plumbing
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
106 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
