Question about Jeep 2008 Liberty Sport
Window Master Switch
Is the power Window master switch (Driver) a fixable part? or am I stuck to spend $50+ to get a new one?
    Genius:
  • 1,198 Answers
Shop Amazon, you'd be surprised at what you find.
Posted on Nov 26, 2013
I have no idea why the window only goes down.
Michael, Inside the window switch are copper contacts that do wear,corrode and become defective. the switch still could be defective even though it works for going down.
Test the switch with a DVOM or test light.
You can google search your particular vehicle for more info on diagnosing power window problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Diagnose your Power Window Problem Is the Switch or motor bad
Power Window Switch Fix How To
Saturn series master power window switch test and bypass
Apr 30, 2016 | Cars & Trucks
1998 olds cutlass driver side window switches dont work except for the switch that controls the passenger side front door window that works but all others dont work, would that mean need a new switch or...
Do the individual door switches work their windows? If so, it would be the driver's side door switch, the master switch, that is bad.
The fact that one window works off the driver switch means that power for the windows is at least getting to the master switch, and that the ground for all power windows is good. If the other door switches work, it is just the master switch, not a wiring problem.
Aug 01, 2013 | 1998 Oldsmobile Cutlass
Power windows don't work
the master window lock switch is stuck on the off possition test for power in and out, remove and replace
Jan 07, 2013 | 2009 Kia Spectra
2003 Dodge Stratus power window
check power window lock out switch on the driver master switch if lock out switch on no power windows wont work.
Sep 27, 2012 | 2003 Dodge Stratus
I have a 2000 Ford Taurus sedan and the back driver side window is the only one that has power, what could be the problem?
power at the back driver's door switch or at the driver's master switch? if power on the master switch cotrols the lr window then you most likely have bad master window switch. if the lr door switch is used to control the lr window then most like you have three bad window motors.
May 26, 2012 | 2000 Ford Taurus
2000 ford explorer master switch problem
Check for broken wires inside the rubber boot from the body to the driver door . Happens all; the time ,wires breaking . Also you should have check for B+ voltage at the master switch before replacing .
How To Diagnose your Power Window Problem Is the Switch or motor bad BUY...
The Trainer 24 Power Window Troubleshooting
Apr 29, 2017 | 2000 Ford Explorer
Passenger side window will not go back up
No.The drivers master power switch is probably bad.YOu will have to perform a test on the three other switches on the master. Check for power and ground when you push each putton.If the master switch fails the test you need a new master switch.
Aug 01, 2009 | 2004 Toyota Camry
Rear side windows
This may be just a case of inadvertently hitting the window lock out n th driver door window switch by mistake. Check that first. Here's some background on window operation
Principles of Operation
The driver power window regulator motor is controlled directly by the master window/door lock/unlock switch (and its integrated "auto down" module). Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The driver power window regulator motor is a reversible motor that is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The passenger power window regulator motor is controlled directly by the passenger power window switch and can also be controlled by the master window/door lock/unlock switch. Power is supplied to the power window relay and the master window/door lock/unlock switch, and the passenger power window switch when the SEC/timer module grounds the coil side of the power window relay. The SEC/timer module will ground this relay when the ignition is in the ON position and will remain energized for approximately 15 minutes or until the driver or passenger door is opened.
The passenger power window regulator motor is a reversible motor, which is operated by applying power and ground to the motor leads to lower the window, and then reversing polarity on those leads to raise the window.
The power rear quarter glass is also directly controlled by the master window/door lock/unlock switch. The power rear quarter glass power latches also utilize reversible motors. The power rear quarter glass power latches are operated by applying power and ground to the motor leads to open the window, and then reversing polarity on those same leads to close the window.
Symptom Chart Condition Possible Sources Action
  • All windows are inoperative
  • BJB Fuse:
    • F20.
  • Circuit.
  • Power window relay.
  • Front door power window switch.
  • GO to Pinpoint Test A .
  • Single power window is inoperative
  • Front door power window regulator.
  • Circuit.
  • Driver door power window switch.
  • GO to Pinpoint Test B .
  • Vent power window is inoperative — quarter window glass power latch
  • Circuit.
  • Quarter window glass switch.
  • Quarter window glass power latch.
  • GO to Pinpoint Test C .
  • The one touch down feature is inoperative
  • Master window regulator and door lock switch.
  • INSTALL a new master window/door lock/unlock switch. REFER to Switch—Master Window Door Lock/Unlock .
  • The back window will not defrost
  • CJB Fuses:
    • F30 (10A).
    • F32 (20A).
    • F34 (20A).
  • BJB Fuse:
    • F27 (45A)
  • Circuit.
  • Heated back window switch.
  • SEC/timer module.
  • Rear window defrost relay.
  • GO to Pinpoint Test D .
  • The back window defrost will not shut off automatically
  • SEC/timer module.
  • Circuit.
  • GO to Pinpoint Test E .
Jan 28, 2009 | 1999 Mercury Villager
Jeep 2008 Liberty Sport Logo
52 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
