Question about Sony Cameras
SONY CYBERSHOT OVEREXPOSURE PROBLEMS
I have a Sony Cybershot Camera / 5.1. Mega Pixels Mpeg/Movie Camera
that is just over a year old. I have never dropped the Camera or abused it any fashion. However, now the Camera seems to overexpose everything shot indoors or out. There are also a number of horizontal bands that run throughout the photo. I bought a new battery, thinking that might be the problem, but to no avail. The Mpeg movie Camera appears to still be fine.
SOURCE:
  • 2985 Answers
SOURCE: Sony Cybershot DSC-W100 Digital Camera
This does depent on the software you are using to print the images- The data is in the images the computer programs has to find it. What program do you use to print?
Posted on Sep 25, 2007
welcomejee
  • 10594 Answers
SOURCE: sony cybershot 7.2 mega pixels
Lens of camera is not being open properly, so it gives "access" message. Try this trick, while puching power up button, tapp the lens or pull upward. Please don't give much force as it can be damaged easily.
Posted on May 28, 2008
SOURCE: cybershot sony 7.2 mega pixels optical zoom 3X-
i'm having the same problem!! I'd like to know what to do to fix this issue.
when i turn it on "turn the power off and on again" and it says it over and over again when i do it.....the lens doesn't come out anymore . It can show my pictures but thats it.
Posted on Jun 25, 2008
welcomejee
  • 10594 Answers
SOURCE: My Sony Cybershot DSC W55
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Posted on Jan 28, 2009
  • 11967 Answers
SOURCE: Sony cybershot digital camera with a stuck lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 03, 2010
I own a Sony Cybershot 7.2 Mega pixels camera. I am not able to use all its features properly in the absence of a user mannual. Can I download one, if yes, from where?
I am not sure about the model number, Visit this link to download manual/user guide for Sony Cybershot, Put model number in Option1 and search manual or you can use Option2 to search manual.
Thanks...!! 4 thumbs rating keep us motivated to answer more free questions.
Oct 08, 2010 | Sony Cameras
Can hear photo/movie being taken, but won't diplay on LCD. Black screen.
Hi Amritraj,
                 This problem is related to a component called CCD IMAGER, And you have to replace the CCD IMAGER,
                 As far as concern about, you heard that sony providing free of cost services regarding CCD IMAGER problem this is true, Therefore contact any nearest SONY SERVIC CENTRE for the replacement of CCD IMAGER free of cost.
Thanks for using fixya.
May 31, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Its known issue of ccd imager in DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 30, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
I need to find the manual for the sony cybershot digatal camera 3.2 mega pixels
manual for Sony DSC-P73 here it is
http://www.docs.sony.com/release/DSCP73.pdf
pls rate me FIXYA for help
Apr 11, 2009 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Sony Cybershot 4.1 mega pixels
my camera won't stay on but the I can review pics no problem. it is a sony cyber shot 4.1 mp
Nov 20, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot DSC-F55 and MPEG Movies
You are viewing the wrong directory. There is one on the camera for stills and one for MPEG's.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Cameras Logo
156 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
