Question about Numark Industries Numark NDX400 Tabletop Scratch MP3/CD Player With USB
Freezing when playing. sometimes when turned on it sticks on boot
I acquired a used, but well kept, good condition Yam CVP-5 clav. Some keys work sometimes, sometimes no keys work. I tried the programming and instrument buttons. Jody Bailey Newcastle Australia
I expect, assuming you did the re-boot routine, that the problem is your key contacts. Contact Yamaha for your nearest service center. Here's the link-
May 18, 2016 | Music
Korg M50 keeps freezing up how to fix took it to repair and it still does it
Well looks like you have a capacitors problem. I had this problem too and a friend soldered two new capacitors in place. You can find information on the korg forum but most important is to know where the capacitors are located
http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=92395
Dec 07, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Korg pa50 freezes at start up and only says "KORG PA50"
I think it is time for you to buy one new one....That you can but on side for parts.
Apr 04, 2012 | Korg Pa50 Professional Arranger Keyboard...
When i hit one pad it get the noise of the single pad i hit plus another pad.. is like I hit two pads at the same time!
A couple of things to check:
Make sure you have a SOLID surface to place the unit since if the surface bounces it may false trigger another pad. See if there is a sensitivity adjustment... sometimes they have setting for playing with hands or with sticks, The sticks one is less sensitive and less subject to false triggering.
Apr 11, 2011 | ION Audio iED04 Desktop Electronic Drum...
I bought mv 8800. I bought converter which converts from 250V-50Hz to 110v 50w So I get into my mv, with vga mode, and i see software with lags, not freezing but for example i play beat, it records not...
This is NOT likely to be a problem with the power source at all but more likely with some setup parameter. Search your manual for subjects like "quantize" and also sampling rates.
Dec 01, 2010 | Roland Mv8800 Production Studio
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
May 23, 2010 | Boss Micro BR Digital Recorder
Roland fantom -x6 freezing
Shipping something to a repair shop is GUARANTEED to TEMPORARILY fix the problem due to vibration in shipping.
Not sure what you are recording to, but if it is an internal hard drive, that would be the prime suspect. Drives are cheap, replace it and format it!
Nov 28, 2009 | Boss Music
Wurlitzer organ, highest key plays note one octave too low.
If this is the kind of organ with the wire sticking out of the key that makes contact with the bus bar to create the note you will have to make sure that key is operating the same as adjacent keys. The busbars have to be clean and the contact wires have to be clean. Sometimes when cleaning the wires they will spring out of place and not make contact with the appropriate bus bars. Check that key against the rest and see what you find. Hope this helps.
May 17, 2009 | Music
Numark Industries Numark NDX400 Tabletop Scratch MP3/CD Player With USB Logo
32 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
