Question about Fisher and Paykel DEGX2 Dryer
Drum won't turn
Top loading, drum won't shut
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Kenmore dryer 110.66912690 .Does the motor shut off when the belt breaks? I know the drum can't turn, but the motor will not run. It just finished drying a load of clothes. Thanks
Yes it has a broken belt switch. This is a 4 wheel drive model. To replace the broken belt. The first thing to do is use your index finger to pop the shoulders off each end of the console. Place your finger on the top of the shoulder and pull towards you till it comes free from the control. This will expose the hold down screw on each end. Remove them next and flip up the console. 3 quarter inch hex heads screws must then be removed to get the top off. Once that is accomplished use a putty knife to release the base panel and remove it. Take care to see how the door switch wires go.remove the filter and filter chute. Remove the door springs then the yellow wire from the drum sensors. Remove the front panel, Remove the drum. Clean er up. My Video:
https://www.youtube.com/watch?feature=player_embedded&v=1VVNRfmbtEA
Dec 17, 2012 | Kenmore Dryers
Drum won't turn
Remove the top to see if the belt is still on.
Nov 23, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have aa frigidaire front load washer model LTF2940FE1. We put a pretty big load of towels in this morning. halfway through the cycle the machune made a couple of loud noises, like it was shaking, and...
Never put a large load of anything in, they're quite frankly not designed to work like that for a number of reasons. If the drum is full then water can't circulate properly and your clothes won't get washed as well as they could do.
The machine shut down to prevent damage to itself, try turning it off at the mains for 30 mins, turning it back on and then putting half the load in. This should reset it and stop the shaking.
Jun 24, 2012 | Frigidaire ATF6000ES Front Load Washer
Siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Apr 12, 2012 | Siemens Washing Machines
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
Water won't shut off on fill
There may be something blocking the pressure tube which measures the water level. This is a tube which runs from the bottom of the drum up to the water level sensor. Disconnect the tube at the drum and check, also blow in the tube and check the water level sensor is working, it should make a clicking sound.
Jul 06, 2011 | Maytag PAV2300 Top Load Washer
Water didn't shut off
There is a part called a air-dome that is connected to the lower section of your outer drum. The part where you put your clothes in is called the inner drum.The air-dome has a small tube connected to it which travels up the drum to a level sensor in the control panel that turns off the water when the washer is full to the point water level is set.This is usually on top loaders.
Feb 06, 2010 | Kenmore 23822 Top Load Washer
Dryer drum won't turn. It has power, the door is shut tight
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Amana NED7200TW Electric Dryer
Fisher and Paykel DEGX2 Dryer Logo
44 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
