Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Loud squeaking maytag bravos MEDB400VQO dryer
abhishek33
  • 1239 Answers
SOURCE: Maytag Neptune Dryer Model # MDE3000AYW
Motor malfunctions usually call for service by a professional. There are three main causes of motor failure: lack of lubrication, a defective motor switch, or worn or frozen bearings. A humming sound can be related to a burned-out motor or a defective switch. Check these trouble spots before you call a professional service person or take the motor to a repair shop. Here's how to check a dryer motor:
Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
If the motor hums, but won't run the pulley on the end of the motor shaft, try turning the pulley by hand.Caution: Before turning the pulley, make sure the power to the dryer is turned off.
Posted on Sep 12, 2008
SOURCE: Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Posted on Mar 24, 2009
localwonder
  • 6784 Answers
SOURCE: maytag neptune dryer makes a loud squeaking noise
This noise will normally come from a defective idler pulley. Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced. Check the bearings as well for excessive clearance also(roller bearings)
Posted on Sep 29, 2009
SOURCE: ''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Posted on Dec 27, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Since you did not provide a model number I picked a similar model for reference using this model number: MDE5721TQO (there are at least 40 different model numbers but the blowers are all the same) You blower is driven directly by the motor so unless the blower itself has come apart or the drive spline in the blower has failed in some way you more than likely have a major build up of lint in your dryer.
You can look here to see the blower location http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133558&diagram_id=1301439#d1301439
You can turn the motor by hand and see if the blower is turning by losening the housing screws for the blower while using a flashlight. If the blower is turning then you need to find out where the blockage of lint has built up and remove it. I would startt around the lint filter. NOTE The drum will also turn.if you rotate the motor pulley. Just make sure the unit is unplugged while you attempt this. If you do locate the blockage I have found that a well bent into a U shaped METAL coat hanger works well. Do NOT poke any sharp objects into the air ducting areas of your dryer while trying to find any blockages and avoid the heating element area with anything metal or sharp. A vacuum crevice tool works great during this task. Good luck and I do hope you are able to locate the problem based on the information here.
Posted on Jan 11, 2010
Maytag intellidry dryer
This could be a lot of things. It could be the belt on the drum, the tension pulley on the belt or something stuck between the drum and the frame. To check it you need to unplug it and see if there is a panel under the door that comes off. There may be screws on the bottom of it. If it does not come off, the whole top lifts off.
Sep 03, 2014 | Maytag Bravos X Series MGDX500XW
How to repair squeaking sound when in operation
it most commonly has to do with the inner wheels needing to be replaced. either the tub wheels or belt wheel.
May 19, 2014 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
There is a squeaking noise upon starting the dryer no matter what size load is in there. it lasts throught the whole cycle. its a pretty loud screeching noise.
Unplug dryer. Remove front kick panel, Remove door. Lift top and lay it back, be sure to support it. Take tension off belt. Remove drum. Replace all worn parts the hold up drum. Check belt tensioner for ware and replace if needed.
Jun 03, 2011 | Whirlpool Maytag Bravos MGD6600TQ Dryer
My Maytag dryer MDE9606AZW has started to squeak, sounds like a fast spinning squeak, sometimes loud and sometimes quieter. What might be causing this and how do I fix it?
It's likely your drum ring bearing has worn out. It's a strip of plastic that keeps the metal parts from rubbing has the barrel turns.
Mar 05, 2011 | Maytag MDE8000 Dryer
Maytag bravos dryer squeaks when it is on. what could be the problem?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Feb 27, 2011 | Dryers
My dryer makes a loud sqeeling noise when its drying clothes our maytag neptune is a gas dryer thats about ten years old
heatman101
ghgh
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer, 25 year old dryer has a loud squeak
Hello.
The squeaking is coming from the rollers that the drum rides on. If you take the model number to a local appliance service store they will have the parts and be able to direct you on replacing them.
Jul 20, 2009 | Maytag PYE2300AY Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
22 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
