Question about GPS
GPS suction to sianbag will not stick to the beanbag dash mount
My GPS will not suction to my beanbag dash mount. I have an extra plexiglass disk should I attach it on top of the old one?
SOURCE: problems with the window mount that comes with the Garmin 360
You just have to push the ball part on the window mount into the socket part that holds the GPS. It's pretty tight, so you have to press pretty hard.
Posted on May 06, 2008
  • 9 Answers
SOURCE: LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Posted on Dec 14, 2008
  • 373 Answers
SOURCE: tom tom gps adhesive plate
Use an 'alcowipe' available from your local chemist.
The alcohol in the wipe will disolve the glue and will not affect your windscreen.
Aternatively get a bottle of 'Spirit Alcohol', also available from the chemists and use a cloth to dissolve the glue
Posted on Feb 26, 2009
JerDiggity
  • 13 Answers
SOURCE: How do you use the dashboard disk to mount the GPS?
The idea behind the disk thing (assuming one side is flat and the other has double-sided tape) is for you to be able to mount the disk, with the tape, pretty much anywhere in your car. Once you've found a good spot, clean that area, then peel off the piece covering the sticky tape and stick the disc on to the spot. Once that's done (won't take more than a few seconds), you should now be able to use the suction-cup on the disc (instead of on the windshield).
Either way, that tape is permanent. When they say permanent, they mean permanent. I lived where the outdoor temp was 100+ degrees everyday, and that thing would not come off. Point is, just make sure you mount it where you want it. Just a heads up. :) Good luck!
Posted on Mar 27, 2009
RamTek
  • 377 Answers
SOURCE: Suction cup does not stick to the base.
  1. If you will stick the suction cup to your windshield make sure to clean it first use dry clothe and put pressure while rubbing it to the windshield.
  2. After cleaning it before you stick the suction cup to the windshield make sure the lock is release and then put a pressure and then while pressing it then that's the time you will lock it.
Posted on Feb 06, 2010
My garmin nuvi suction cup gps mount will not stick to my dashboard what will help?
You need a dash disc as the suction mount needs a very smooth surface. Disc are available at GPSNSTUFF.com.
Jul 02, 2014 | Garmin GPS
I just bought my gps but i dont know how you turn on it on? and what is the circle disk for?and where should i connect the handle at? i dont get it...
The unit has a slide switch on the side. If you are asking how to mount the unit, it came with a bracket that snaps on (there are indentations in top and bottom where it hooks in). Then you pop the ball mount into the receptacle on the back. The circle disc to which you refer is for PERMANENT dash mounting. It has double sided tape that sticks to the dash. You can then use the suction mount on the disc instead of the windshield. I hope this helps.
Oct 01, 2010 | Garmin nuvi 250W GPS Receiver
How do I attach my garmin to my dash mount?
The Garmin Nuvi 255w comes with a three piece dash mounting kit. A round disk smooth on one side tape on the other to affix to the dash (most dashes ar textured and the suction cup will not hold to textures) a suction cup arm with a ball end, and a bracket with a receiver for the ball. Snap the bracket and arm together, this can take a little effort. mount the disk to your dash in a place that doesn't obstruct your view of the road. then place the arm/bracket on the disk and push the lever down creating suction to hold the mount to the dash.
Another option it the beanbag dash mounts that hold the arm without sticking to your dash.
If this answered your question please check +. If not please elaborate on your queston
Apr 26, 2010 | Garmin nuvi 255W GPS Receiver
We installed the car cradle to the windshield but receiver won't adhere to the disk. Please tell us what we did wrong. Thanks, Pat skillman
i think you mean the mount wont adhere to the disk..normally the disk is not used to mount the gps to the windshield, is more for the dash area or another spot where the suction cup wont adhere. the are rare occasions where the disk is needed for the windshield though, but its rare. try ataching it to the windshield without the disk. lift lever at suction cup, press the mount firmly against the windshield, then press the locking lever down to secure the mount. the picture below is the wount in the unlocked position.
form Magellan
This adhesive disk provides an alternative to mounting your Magellan GPS to the windshield of your vehicle. The disk adheres firmly to your dashboard or virtually any surface. Then attach the suction cup of your windshield mount to the disk.
Aug 14, 2009 | Magellan Roadmate 1200 Car GPS Receiver
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
My problem is how to use the Dash moount disk for the Garmin 350? My real problem is getting the answer?
The dashmount disk has a sticky side that should be pealed and stuck to the dash - then use the windshield sticking cup to stick to the dash mount smooth side...
Jan 13, 2009 | Garmin Suction Cup Mount F/ Nuvi 350
I just bought the magellan maestro, and I can't get the suction cup to stick. The surface is clean and we wet it, but it loosens rapidly.
The GPS unit comes with an adhesive disk that must be installed on the surface where you want to place the GPS unit. The suction cup will only work with this adhesive disk. Once the adhesive disk is installed, the suction cup will hold. Here's the instructions magellan web site...
  1. Clean and dry the dashboard where the adhesive disk is going to be installed using enclosed alcohol pad.
  2. Remove the protective paper cover from the bottom of the adhesive disk; place the bottom of the adhesive disk firmly on the dashboard.
  3. Apply even pressure on the top of the adhesive disk for a secure fit (Allow 24 hours to cure).
  4. Place suction cup mount on top of adhesive disk.
  5. Firmly press suction cup mount down flat against the adhesive disk, press the suction cup lever down to secure the suction cup to the adhesive disk.
Nov 03, 2008 | Magellan RoadMateā„¢ 1212 Car GPS Receiver
Help
Greetings,
Amazon has a ton of options. I personally like the beanbag mount. It works very well.
Click HERE to see a list.
Take Care,
-WN
Oct 02, 2008 | Garmin Nuvi 660 GPS Receiver
Installing my new street pilot
It is a mount for your dash that your suction cup mounts to just paste it to your dash ans put the suction cup on it and install your unit
Dec 20, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
35 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
