Question about Car Audio & Video
2004 Ford F150 makes a loud whining sound when started below 32 degrees
    Genius:
  • 1,198 Answers
Check your antifreeze, it may be too diluted.
Posted on Nov 25, 2013
2004 Ford F150 makes a loud whining sound when first started below 32 degrees
Get your alternator checked at Auto Zone for free. It could also be your power steering unit, because it sounds as if a bearing is going out of something that is driven by your timing belt.
Nov 25, 2013 | Car Audio & Video
Symptons of a bad transmission
Slow acceleration due to slipage, whining noises and just won't go into any gear or no reverse.
Jun 28, 2012 | 2004 Ford F150
Just had the rear end of my 02 f-150 serviced new pinion seal and new fluid. Now truck drives with a vibration and make a loud rubbing sound when turning.
would look below and check before driving again. check prop-shaft not loose and check all wheel nuts. also contact garage that done work.
May 01, 2011 | 2004 Ford F150
When I put my 2004 ford into 4x4 the left front starts to hum or whine like something is rotating free. It sounds like something is not connecting. I changed the actuator on the same side last year.
I would check to maek sure that your lock out hub didnt brerak off. My 2005 for f250 did that last year to me but on my right side. It sounded like a humming noise and got loude as i wen faser. After several weeks of tolleraing It I tore it apart and foind tha the hub was not releasing after putting it in 4 wheel drive. So my passenger side was locked in bu my drive side unlocked. I would try that as a first step. Itt should only be 3 tiny bolts on the hub itself. Mine are held on by 3 allen wrench head syle bolts. Hope this helps.
Jan 26, 2011 | 2004 Ford F150
2004 f150 has a slight whining noise coming from the transmission on acceleration. Changed fluid and it still is present. What next without breaking the bank
It sounds like you have something rubbing against the drive shaft or your torque converter is having a problem. This leaves you with only one choice really, have the transmission serviced and checked by a transmission shop.
Sep 01, 2009 | 2004 Ford F150
Loud Ticking sound 2004 F150
Check the Alternator / Powersteering belts .
One of them will be damaged and loose.
Hope this helps.
Jul 28, 2009 | 2004 Ford F150
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
