Question about GE J Series 20.6 cu. ft. Top Freezer No-Frost Refrigerator TBX21JABWW
Water problem My problem is the water from my refrigeratoris running down from somewhere inside my refrigerator and piling up under my bottom baskets then running on my floor. please help. model: GE:  TBX21    Gary/NYC
  • Chris Vickroy Oct 17, 2008
    With some research I found that you have to unblock the plugged line to allow cup to drain, and that the cup is contained within a controller at the back of the fresh foods compartment. I need help with that. However, I cannot figure out how to get into the controller area to access the cup. I also found out that a turkey baster filled with warm water and baking soda, shot up through the tube, will help unblock it. I will try that later today.
  • john ortiz
    john ortiz Aug 19, 2014
    Look in the back of frigerator, you will see a black plug like with a tube going down. Turn the black plug like thing left or right to remove tube and plug. Take plug to sink and run hot water til its clear. Just did this to mine, and now it works with no more water mess.
  • 291 Answers
Sounds like the  drain for the defrost system is plugged....
Posted on Oct 11, 2007
Our fridigaire is running extra cold(some items are freezing) on the icebox side & the automatic water despenser is not working.when we turn down the control from setting 3 to setting 2 or 1, we can...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 06, 2011 | Frigidaire Refrigerators
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Water at bottome of refrigerator
Under the draws in the back, there should be a drain hole that drains water down to the drain pan under the unit. Check to make sure it's not blocked with food or frozen water.
Jul 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator has water dripping inside the unit down the back
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Apr 19, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking in the freezer compartment. Water running out of the bottom of the freezer. Does not leak all the time. Turned the ice maker off. Still have water on the floor. This is a Maytag wide by side,...
Are you sure the water is from the water line?
Usually, water inside a refrigerator is defrost water that is not flowing in the direction it is supposed to be going. The defrost water flows into a catch basin behind the inner lining of the refrigerator. From there it goes into a plastic tube which carries it underneath the unit to a pan. The heat from the coils and compressor then evaporate it.
On most refrigerators you can see this tube at the rear. It should exit the unit somewhere and run downward. See if you can detach this tube and make sure it is not blocked. Another possibility is that the catch basin inside the refrigerator is clogged. Checking this would not be easy. The inner lining of the refrigerator would have to be removed. I have seen these basins filled with debris and ice. This can shut of the flow of the defrost water completely. The water has to go somewhere, and it flows inside the refrigerator.
Oct 20, 2009 | Refrigerators
Water in bottom of refrigerator
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jul 07, 2009 | Refrigerators
Our maytag side by side refrigerator is leaking from the freezer
Check the filter. See if its connected right. Sometimes the old (BAD-need replacement) filter back pressure the water and if the seal or gasket is not good enough, you will have water leak. But in this case you will notice the water path inside the fridge too.
Jun 18, 2009 | Maytag MSD2656G Side by Side Refrigerator
Water inside chefmate refrigerator
Moisture inside the 'fridge condenses on the coolest parts. Most are designed so that the moisture runs down into a channel and is directed out through a small tube somewhere at the back of the compartment, near the bottom.
I would guess that the tube is blocked near the top.
Try finding the tube and carefully inserting something flexible down it to clear the blockage. Don't use anything too rigid, or anything metallic, as these may damage the tube and cause more serious problems. I have done this before using a pipe cleaner.
Jun 06, 2008 | Refrigerators
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerator
there is a drain hole at back of your fridge on the inside which is probely blocked take out the shelfs you should see a channel in the middel that where the drian hole is situated unblock the drain hole[DO NOT USE A SHAPE INSTRUMENT ]hope helps
Sep 20, 2007 | Refrigerators
Refrigerators Logo
438 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
