Question about Hardware & Accessories
HEATED SEAT SYSTEM
Darrell
2007 SRX pedals, adjustable quit, front drivers seat and both heater switches All quit at same time what could have done this? Passenger power seat still works?
Electronic's ! drivers Power seat module , driver door module . Do you know anything about automotive electronic's ?
The heated seat module (MSM) controls heated seat operation for both the driver and passenger seats. There are 2 modes of operation available for heated seats; both the seat cushion and seat back heat, or seat back only heat. When a heated seat temperature signal request is received, the MSM will activate both the seat cushion and seat back heating elements. When the heated seat BACK ONLY mode button is pressed once the MSM will deactivate the seat cushion heating element and leave the seat back heating element ON.
The adjustable pedal system is controlled by the memory seat module (MSM).
your best bet , have a qualified repair shop check it out ! Could have DTC'S - diagnostic trouble codes in door module , BCM etc...
Mar 15, 2018 | 2007 Cadillac SRX
Heated drivers seat dont work on my 1998 lincoln contenital
It could be the heating element or the Driver heated seat module ! Do you know anything about automotive electronic's ? Circuit testing with a DMM - digital multi-meter ? This system has a element in the seat an the back . None work ?
  • Heated Seat Inoperative
  • Circuitry open/shorted.
  • Damaged heated seat heater elements.
  • Damaged heated seat module.
  • Damaged heated seat switch.
  • GO to Pinpoint Test G .
PINPOINT TEST G: HEATED SEAT INOPERATIVE G1 TEST HEATER ELEMENTS
  • Disconnect connectors C352 LH ( C356 RH) at heater modules.
  • Using an ohmmeter, measure resistance of heater elements according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 12 1067 (P/LB) 9 1066 (GY/LB)
Is resistance of elements 2.5-10 ohms?
Yes No GO to G2 . GO to G4 .
The seat heater module is under the driver seat .
G2 TEST HEAT SENSORS FOR OPEN CIRCUIT
  • Using an ohmmeter, measure the resistance of sensors according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 11 1063 (O/LB) 10 1062 (R/LB) 6 1061 (BR/LB)
Is resistance more than 10,000 ohms?
Yes No REPLACE trim covers. RESTORE vehicle. RETEST system. GO to G3 . G3 TEST HEAT SENSORS FOR SHORT CIRCUIT
  • Using an ohmmeter connected to a known good ground measure resistance of Circuit 1063 (O/LB) at Pin C352 LH; Pin C356 RH.
  • Measure resistance of Circuit 1061 (BR/LB) at Pin C352 and Pin C356 .
Is resistance 0 ohms?
Yes No REPLACE trim covers. RESTORE vehicle. RETEST system. GO to G6 .
G4 TEST CIRCUITS BETWEEN HEATER MODULE AND HEATING ELEMENT CONNECTOR
  • Disconnect connectors C353 and C351 LH.
  • Disconnect connectors C355 and C354 RH.
  • Using an ohmmeter, measure resistance of circuits between module connector and heater element connector according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 12 1067 (P/LB) 11 1063 (O/LB) 6 1061 (BR/LB) 10 1062 (R/LB) 9 1066 (GY/LB)
Is resistance less than 5 ohms?
Yes No GO to G5 . SERVICE suspect circuit for open. RESTORE vehicle. RETEST system.
G5 TEST HEAT ELEMENT AND SENSOR CIRCUITS FOR SHORT TO GROUND
  • Refer to Circuit charts in G4.
  • Using an ohmmeter connected to known good ground, check resistance of circuits.
Is resistance less than 10 K ohms?
Yes No SERVICE suspect circuit for short to ground. RESTORE vehicle. RETEST system. Circuits satisfactory. REPLACE trim cover. G6 TEST HEATED SEAT SWITCH POSITION 1
  • Disconnect connector C352 LH ( C356 RH).
  • Make sure switch is in position 1.
  • Using an ohmmeter measure resistance between Pin C352 , Circuit 1018 (LG/O) and Pin C352 , Circuit 1019 (T/LB).
  • Measure resistance between Pin C356 , Circuit 579 (BK/O) and Pin C356 , Circuit 580 (BR).
Is resistance between 2.0 K and 2.75 K ohms?
Yes No GO to G7 . GO to G14 .
Jan 07, 2018 | Lincoln Cars & Trucks
Seat heater comes on by itself in 2004 yukon denali
Heated Seat Components
The heated seat system consists of the following components:
• Driver and passenger heated seat switches
• Driver and passenger seat back heater elements
• Driver and passenger seat cushion heater elements
• Driver and passenger seat back temperature sensors
• Driver seat module
• Driver door module
• Passenger door module
When there are modules involved in the operation of any componet that's acting up , the module's electronic's could be the culprit ! But without testing who's to say what the problem could be !
I would have it check for DTC'S
DTC B2425 or B2430
The driver and passenger seat heaters are controlled by the driver seat module. Power is supplied to the driver seat cushion and back heater elements through individual voltage supply circuits. Power is supplied to the passenger seat cushion and back heater elements through a common voltage supply circuit. All of the driver and passenger seat heater elements are grounded by the driver seat module through individual low side drive control circuits. The heater element control circuits are pulse width modulated to ground by the driver seat module in order to control the seat temperatures by regulating the current flow through the heater elements.
DTC B2435 or B2440
The driver seat module relies on inputs from thermistors installed in the driver and passenger seat backs to control heated seat temperatures. The thermistors are 2-wire sensors supplied with a 5-volt referenced signal circuit and low reference circuit from the driver seat module. Resistance through the thermistors varies with temperature causing the heated seat sensor signal circuit voltage levels to decrease as the seat back temperatures rise.
Install a scan tool.
Start the engine.
Turn the heated seat ON.
With a scan tool, observe the Heated Seat Sensor parameter in the data list for the driver seat module.
Does the scan tool indicate that the heated seat sensor parameter is within the specified range?
0.078-4.94 V
Dec 08, 2016 | GMC Yukon Denali Cars & Trucks
2007 Buick Lucerne CXL: Cooled seats not working. LIghts come on, temperature adjusters work but the motors under the seats do not come on.
Air Circulation
When the heated/cool seat switch is pressed to initiate operation of the climate control seat (CCS) system, cabin air is drawn through the heated/cool ventilation module air filter, then directed through passages in the foam of the seat cushion and seat back to the seat's occupant. In order for the CCS system to operate to its optimum performance, it is crucial to have unrestricted air flow through the system. A dirty or restricted air filter, the blockage of an exhaust air duct, a misaligned heated/cool ventilation module, or incorrect foam installation of the seat cushion or seat back will all have negative effects on CCS operation.
Heated/Cool Ventilation Module
Each heated/cool seat has 2 ventilation modules, one located under the seat cushion and one located in the seat back. These modules are controlled by the climate control seat module (CCSM). Each ventilation module contains a thermo-electric device (TED), a temperature sensor, and a blower motor. The TED and temperature sensor are mounted downstream of the blower motor. Each TED consists of a circuit of positive and negative connections sandwiched between 2 ceramic plates. Each ceramic plate is equipped with copper fins for heat exchange. The air flowing past these fins is either directed as conditioned air into the seat cushion and seat back, or directed into the cabin as waste air.
A TED is essentially a solid state heat pump that is used to heat or cool the air supply to the seat cushion and seat back. When voltage is applied to a TED, one side releases energy as heat, while the opposite side absorbs energy and gets cold. When the polarity of the current flow to the TEDs is switched, the hot and cool sides of the TED reverse.
During the following climate control seat system description and operation, the TEDs, blower motors, and temperature sensors will be referenced independently even though they are all packaged together as a module.
Climate Control Seat (CCS) System
The CCS system consists of two heated/cool ventilation modules and one climate control seat module (CCSM) that controls both the driver and passenger heated/cool seats systems. The CCSM is mounted below the front passenger seat cushion. It receives power from both, battery positive voltage and ignition 3 voltage.
Once a CCS system is activated, cabin air is drawn through the seat blower motors and directed across the fins of each of the thermo-electric device (TED) located under the seat cushion and in the seat back. The air is either heated or cooled as it passes over the TEDs. This conditioned air is then directed through channels in the foam of the seat pad and through small holes in the seat cover to the occupant. Once the system is activated, the CCSM uses a set of algorithms to control the temperature of the selected heating or cooling modes.
Your best bet is to take your vehicle to a qualified repair shop an have it diagnosed .
DTC B19A4: Driver Seat Back Blower Speed Circuit High
DTC B19A8: Driver Seat Back Blower Speed Circuit Short to Ground
DTC B103D: Driver Blower Power Circuit
DTC B272E: Driver Seat Back Blower Circuit Open
DTC B19A3: Driver Seat Cushion Blower Speed Circuit High
DTC B19A7: Driver Seat Cushion Blower Speed Circuit Short to Ground
DTC B2729: Driver Seat Cushion Over Temperature
DTC B19A2: Passenger Seat Back Blower Speed Circuit High
DTC B19A6: Passenger Seat Back Blower Speed Circuit Short to Ground
DTC B111D: Passenger Blower Power Circuit
DTC B272F: Passenger Seat Back Blower Circuit Open
DTC B19A1: Passenger Seat Cushion Blower Speed Circuit High
DTC B19A5: Passenger Seat Cushion Blower Speed Circuit Short to Ground
DTC B272A: Passenger Seat Cushion Over Temperature
Driver and Passenger Heated/Cool Seats Inoperative
  1. Ignition OFF, disconnect the C1 harness connector at the CCSM.
  2. Test for less than 5 ohms between the ground circuit terminal M and ground.
  3. ?‡'
    If greater than the specified range, test the ground circuit for an open/high resistance.
  4. Verify that a test lamp illuminates between the B+ circuit terminal E and ground.
  5. ?‡'
    If the test lamp does not illuminate, test the B+ circuit for a short to ground or an open/high resistance.
  6. Disconnect the C2 harness connector at the CCSM.
  7. Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 1 and ground.
  8. ?‡'
    If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
  9. If all circuits test normal, replace the CCSM.
Sorry
Jul 10, 2016 | 2007 Buick Lucerne CXS Sedan
Trying to find which fuse is for the heated seats on a 2004 ford explorer sports trak
Heated Seats
This system allows the electrical heating of the front seats on passenger demand.
The components of the system are:
  • the seat heating elements located in the seat cushion and backrest.
  • the heated seat control switch, located on the seat side trim panel.
  • temperature sensors located in the seat cushion heating elements.
  • heated seat relay.
Do both front seat heaters not work ? Do you know how to test electrical circuits with voltmeter ?
PINPOINT TEST J: THE HEATED SEAT IS INOPERATIVE Test Step Result / Action to Take J1 CHECK HEATED SEAT SWITCH OPERATION
  • Key in ON position.
  • Press the heated seat switch on the driver and passenger seats.
  • Are both heated seat switch indicators illuminated?
Yes
If both indicators illuminate, Go To Pinpoint Test K . If only one indicator illuminates, GO to J5 .
No
GO to J2 . J2 CHECK THE HEATED SEAT RELAY CIRCUITS
  • Key in OFF position.
  • Disconnect: Heated Seat Relay C3250 (located under the driver seat).
  • Measure the voltage at heated seat relay C3250-86, circuit 1003 (GY/YE), harness side and ground; and between C3250-30, circuit 566 (DG), harness and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to J3 .
No
REPAIR inoperative 1003 (GY/YE) or 566 (DG) circuit. TEST the system for normal operation. J3 CHECK HEATED SEAT RELAY GROUND CIRCUIT
  • Measure the resistance between heated seat relay C3250-85, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to J4 .
No
REPAIR circuit 57 (BK). TEST the system for normal operation. J4 CHECK THE HEATED SEAT RELAY
  • Install a fused jumper lead between heated seat relay 3250-30, circuit 566 (DG), harness side and heated seat relay C3250-87, circuit 1064 (YE/LB), harness side.
  • Do both heated seat indicators illuminate when pressed?
Yes
INSTALL a new heated seat relay. TEST the system for normal operation.
No
REPAIR circuit 1064 (YE/LB) to switches. TEST the system for normal operation. J5 CHECK INOPERATIVE HEATED SEAT SWITCH INPUT
  • Disconnect: Heated Seat Switch C320 (Driver) or C321 (Passenger) for the inoperative heated seat.
  • Measure the voltage between heated seat switch C320-2 (driver) or C321-2 (passenger), circuit 1064 (YE/LB), harness side and ground .
  • Is the voltage greater than 10 volts?
Yes
GO to J6 .
No
REPAIR circuit 1064 (YE/LB). TEST system for normal operation. J6 CHECK CIRCUIT 57 (BK) FOR AN OPEN
  • Measure the resistance between heated seat switch C320-4 (driver) or C321-4 (passenger), circuit 57 (BK), harness side and ground.
Yes
INSTALL a new heated seat switch. TEST the system for normal operation.
No
REPAIR circuit 57 (BK). TEST the system for normal operation It's not that simple , being a fuse . It's probably the relay or the heating element .
PINPOINT TEST K: SEAT DOES NOT HEAT BUT THE HEATED SEAT INDICATOR ILLUMINATES WHEN PRESSED ? Does it ?
Your best bet would be to take to a qualified repair shop .
Do
Jun 29, 2016 | 2004 Ford Explorer Sport Trac
Front heated seats will not turn on. checked for fuse but cant find any labeled for front heated seats? any ideas
First, please read this article: Where's The Fuse?
In order to obtain conclusive testing of the heated seat system, the Controller Area Network (CAN) data bus system must be checked.
The most reliable, efficient and accurate means to diagnose the heated seat system requires the use of a Scan Tool and the Service and Body Diagnostic Information.
Diagnostic logic is built in to the seat module and the instrument cluster (CNN) to help the person trying to locate the problem by the most efficient means possible. Anytime a problem is suspected, a Scan Tool should be obtained and used to retrieve any stored fault codes in the heated seat module and/or instrument cluster.
Feb 21, 2011 | 2007 Chrysler Aspen 4x2
2002 Oldsmobile Bravada power seat and heated seat is not working. (Passenger side)
Either have broken wires leading to the heated seat and the power seat controls, or the heated seat element is burnt out (but not likely).
Check for blown fuses for the system, but if one side or the other is not working, it's more likely a wire broke somewhere, in this case, on the passenger side.
Dec 18, 2010 | 2002 Oldsmobile Bravada
When I turn on the seat heater on the drivers side, it will stay on for about 10 seconds and then it goes off. Cannot turn it back on until the car if turned off/on. Seat doesnt ever heat up. Passenger...
Here is a heated seat TSB for cars built prior to 12/14/07
TSB 09-4-8
03/09/09
INOPERATIVE HEATED SEAT(S) - BUILT
BEFORE 12/14/2007
FORD:
2005-2007 Five Hundred, Freestyle
2008 Taurus X, Taurus
MERCURY:
2005-2007 Montego
2008 Sable
ISSUE
Some 2005-2007 Freestyle, Five Hundred, Montego and 2008 Taurus, Sable and Taurus X vehicles built before 12/14/2007 may exhibit an inoperative heated seat(s). This concern may be caused by an intermittent open element in the heated seat mat.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
The heated seat system is controlled by the heated seat module located underneath the front passenger seat cushion. The heated seat switches are part of the heating ventilation air conditioning (HVAC) module but the heated seat system operates independently from the climate control system. The heated seat module regulates seat temperature by monitoring resistance of a thermistor type thermostat located in the cushion heater mat. The heated seat module is designed to remain on, heating the seat and maintaining temperature until switched off. For vehicles built before 5/1/2006, the module will time-out and switch off after 10 minutes.
1. Refer to Workshop Manual (WSM), Section 501-10 for pin point test on inoperative heated seat(s).
a. When testing the heater mats resistance and circuits for an intermittent open, technicians should sit in the seat while testing the circuit resistance, move the seat in multiple seating positions and apply pressure to several areas of the heated seat mat to ensure the mat element is not open intermittently.
2. Refer to WSM 501-10 for heated seat element replacement when an open electrical circuit has been identified.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
MT090408 Use SLTS Operations If Actual
Available Or Labor Time
Performed As Actual Time
DEALER CODING
CONDITION
BASIC PART NO. CODE
14D696 28
I hope this helps to solve it.
Oct 06, 2010 | Ford Taurus X Cars & Trucks
The driver seat heater just quit. all fuses are good. how do you tell if the relay is good?
Swap it with a relay you know to be good and see if it works again,pick a relay that is not important to the function of your car.
Nov 01, 2009 | 2004 Cadillac SRX
2002 Grand Cherokee Heated Seats don't work
I will post it in 2 different posts because its too long DB
HEATED SEAT SYSTEM
Individually controlled driver and passenger side electrically heated front seats are available factoryinstalled optional equipment on this model, when it is also equipped with the power seat option. The heated seat system allows both the driver and the front seat passenger the option to select one of two seat heating ranges, Low or High, or to turn the individual seat heaters OFF using the heated seat switches located in the center lower bezel near the bottom of the instrument panel center stack. The heated seat switch circuit operates on ignition switched battery current supplied through a fuse in the junction block, only when the ignition switch is in the ON position.
  • Heated seat elements
  • Heated seat sensors
  • Heated seat module (or memory heated seat module)
  • Heated seat switches.
The heated seat system also relies upon resources shared with other electronic modules in the vehicle over the Programmable Communications Interface (PCI) data bus network. The PCI data bus network allows the sharing of sensor information. This helps to reduce wire harness complexity, internal controller hardware, and component sensor current loads. At the same time, this system provides increased reliability enhanced diagnostics, and allows the addition of many new feature capabilities. For diagnosis of these electronic modules or of the PCI data bus network, the use of a DRB scan tool and the proper Diagnostic Procedures are recommended.
The electronic modules that may affect heated seat system operation are as follows:
  • Body Control Module (BCM) - Refer to Body Control Module in Electronic Control Modules for more information.
  • Heated Seat Module (HSM) - Refer to Heated Seat Module in Electronic Control Modules for more information.
  • Memory Heated Seat Module (MHSM) - If the vehicle is equipped with the Memory System, refer to Memory Seat Module in Electronic Control Modules for more information.
Refer to Power Seats Premium I/III in the Contents of Wiring Diagrams for complete circuit diagrams. Following are general descriptions of the major components in the heated seat system.
The heated seat system will only operate when the ignition switch is in the ON position, and the surface temperature at the front seat heating element sensors is below the designed temperature set points of the system. The heated seat system will not operate in ambient temperatures greater than about 41 °C (105 °F) . The front seat heating elements and sensors are hard wired to the Heated Seat Module (HSM) or the Memory Heated Seat Module (MHSM).
The heated seat switches are hard wired to the Body Control Module (BCM). The BCM monitors the heated seat switch inputs, then sends heated seat switch status messages to the HSM or MHSM over the Programmable Communications Interface (PCI) data bus. The HSM or MHSM contains the control logic for the heated seat system. The HSM or MHSM responds to the heated seat switch status messages, ignition switch status messages, and the front seat heating element sensor inputs by controlling the output to the front seat heating elements through integral solid-state relays.
When a seat heater is turned ON, the sensor located on the seat cushion electric heater element provides the HSM or MHSM with an input indicating the surface temperature of the seat cushion. If the surface temperature input is below the temperature set point for the selected Low or High heated seat switch position, the HSM or MHSM energizes the integral solid-state relay, which supplies battery current to the heating elements in the seat cushion and back. When the sensor input indicates the correct temperature set point has been achieved, the HSM or MHSM de-energizes the solid-state relay. The HSM or MHSM will continue to cycle the solid-state relay as needed to maintain the temperature set point.
The HSM or MHSM and the seat heater elements operate on non-switched battery current supplied through the power seat circuit breaker in the junction block. However, the HSM or MHSM will automatically turn OFF the heating elements if it detects an open or short in the sensor circuit, a short or open in the heating element circuit causing an excessive current draw, or when the ignition switch is turned to the OFF position.
See the owner's manual in the vehicle glove box for more information on the features, use and operation of the heated seat system.
I WILL POST THE REST
Jan 31, 2009 | 2002 Jeep Grand Cherokee
Hardware & Accessories Logo
590 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
