Question about Midwest Metals 162 Critter Nation Double Unit with Stand
Will this Cage work for a Teddy Bear Hamster?
Will my Teddy Bear Hamster Escape this cage?
How can i make my hamster shut up, i need sleep!?
Cover the cage at nite so it is dark inside and then the hammie should sleep also.
Jan 04, 2017 | Rodents
Steam clean a teddy bear
Yes. Teddy can have a light. warm bath in the sink with washing up liquid.
Leave him the sun to dry..be gentle. Teddy has feelings!
Mar 08, 2014 | Office Equipment & Supplies
My hamster keep escaping
don't worry, my daughter's hamster used to escape all the time. Take a look at this website. It has some really great info that you can read to understand hamsters a bit better and to learn some tips to stop yours from escaping.
http://www.hamster-club.com/behaviour.asp
Sep 06, 2012 | Pets - Others
What's a travel bird cage?
The travel bird cage is usually a smaller version of a normal bird cage. The travel bird cage does not need to be large, nor does it need to be as durable as your bird cage. Be sure that your bird can comfortably fit in this cage for a short amount of time so that it will not become stressed.
Aug 05, 2012 | Birds
What is the best toy for my hamster?
I can tell you that I have the Dazzle Run-about Ball and my hamster absolutely loves it. It is a great solution to keep the hamster in while cleaning the cage and it is an amazing exercise too. Check it out at: http://www.petco.com/product/101969/Super-Pet-Dazzle-Run-about-Ball.aspx?CoreCat=certona-_-ProductListTopRated_Gerbil_2-_-Super%20Pet%20Dazzle%20Run-about%20Ball-101969#description-tab
May 15, 2012 | Pets - Others
What is the best sort of cage to keep a hamster in?
Glass aquariums areideal hamster cages, ensure that there is a place with lots of bedding for themto sleep and plenty of things for them to do and they like to use wheels. Oldtoilet rolls make great little tubes for them to run around.
May 13, 2012 | Pets - Others
Blower motor relay keeps blowing
When your blower motor relay (resistor) goes out, it's a good time to drop the blower motor assembly and check for any obstructions in the fan cage (looks like a hamster wheel). Some examples I've come across in the shop over the years include: leaves, twigs, huge amounts of cotton stuffing that mice have dragged in, and once the actual deceased mouse. Those things overwork/overheat the draw and can pop the resistor in a heart beat.
Also, if there are no obvious obstructions, it could be that the blower motor has too much resistance and needs to be replaced simply due to age/long-term usage.
Looking around online the blower motor resistors seem to run $25-$35 and the replacement motor assembly with fan cage is around $60. If there isn't anything stuck in the fan cage, I'd replace both items.
Please let me know how you make out.
Mar 22, 2011 | 1991 Mazda Navajo
Midwest Metals 162 Critter Nation Double Unit with Stand Logo
78 people viewed this question
Top Midwest Metals Pets - Others Experts
Ross Keen
Anglia Clipper...
Tom Chichester
Are you a Midwest Metals Pets - Other Expert? Answer questions, earn points and help others
