Gentle annie MY gentle annie started overflowing this morning as it was filling it up. We turned it off and now it just screams. Makes a high-pitched sound.
    Genius:
  • 1,198 Answers
The fill switch may have failed or the tube to it broke. Anyway, the machine probably is too full of water for it to start to spin out, so it slips on the belt and that makes noise.
The machine is going to be very heavy if it is overfull, but try to let some water out. Maybe you can just lower the drain hose way down into a bucket and get some water out of it. Once it's low enough, it may be able to pump out the rest. Then you can find out about the fill switch.
If it's not overfull, then some hose came loose or broke.
Posted on Nov 26, 2013
  • Monika Welch
    Monika Welch Nov 26, 2013
    Thankyou!! awesome. we have drained it and the lights are working etc. But where is the 'fill switch' to check?
  • mike kirschbaum
    mike kirschbaum Nov 26, 2013
    The fill switch will be on the end of a small hose coming from low on the tub. It usually looks like a flying saucer. Check to see if it clicks when you fiddle with the adjuster screw, which usually is sealed. If it doesn't click, it may be faulty. They are not expensive.
fanny
  • 146 Answers
SOURCE: high pitched noise
The inlet valve is faulty and needs to be replaced.
Posted on Nov 03, 2007
SOURCE: gentle annie motor wiring
This according to googled results, and somewhat verified by me:
For the Gentle Annie connect the white/orange/green wires together to from a
star point and the three other ends (red, yellow & blue) go to your 3 phase
rectifier.
You can leave the others hanging. Don't form the star point with the wire
that's green with a yellow stripe, that's the chassis earth. The brown,
purple, and brown with black stripe I think are sensing coils, with a star
point connected to the black wire. 1.4ohm each, whereas the main coils are
4.8ohm and apparently rated for 5A.
Posted on Feb 01, 2009
App King
  • 55 Answers
SOURCE: LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Posted on Jul 16, 2009
  • 57 Answers
SOURCE: I have a Fisher and Paykel ECS Gentle Annie GW52-k
Make sure there is voltage going to the valve solenoids. That is what opens up and lets water into the washer. You will have to open up the top of the washer control. The valve assembly is where the hoses screw in the back. I don't have the technical on it but most likely should be 120V. Sometimes the valve goes bad and won't open up.
Posted on Feb 17, 2010
TheMobilian
  • 8220 Answers
SOURCE: my dryer makes this high pitch screaming
In the cradle where the center drum bearing fits is a plastic bearing mounted on a metal bracket. When that plastic bearing wears down the ball begins to contact the metal bracket. Bad things are ahead also. Because now as the drum turn the bracket is cutting into the ball.c44ef56.jpg
A typical Laundry center repair manual
Posted on Mar 12, 2010
Dishwasher starts and gets somewhat filled then starts making a high pitched screaming
The reason the dishwasher gives the high pitch screaming is because there is some sort of system error in it.
Try to troubleshoot it from the procedure in the users manual, to detect the fault and fix it.
Take care
Jul 06, 2010 | Maytag 24 in. MDBH950AWS Built-in...
High pitched 'screaming' sound
try checking the fan could be it needs a bit of oil or reolacing.
May 25, 2010 | InFocus ScreenPlay 4800 Multimedia...
Fisher & Paykel Gentle Annie washing screeching sound
remove drive belt.check 2 see if main drive pulley turns freely.check to see if motor turns freely. could b belt. what country r u in . parts hard 2 get in australia. please reply 4 more help. please turn off power b4 u work on it. do not want any accidents.good luck
Apr 04, 2010 | Washing Machines
High pitch scream after i260 scans a few pages. Scanning stops
the main board in that scanner is going bad which is why its making the high pitch sound. Time to get another scanner or call Kodak and get a replacement scanner or go back to the store where you got it from and get a new one.
Jan 23, 2010 | Kodak Office Equipment & Supplies
91 S-10 it has a high pitch scream
It sounds like a worn or loose fan belt. It's slipping on the pulleys causing the screeching noise.
Nov 22, 2009 | 1991 Chevrolet S-10
It makes a high pitched whine at about 62 mph
Vacume line off of transmission won't alow high gear and at that speed the tranny starts screaming for relief. Find the vucume line and make sure its good and connected at both ends
Nov 16, 2009 | 1991 Volvo 240
Hi i have hust turned my laptop on and it is making a biig noise and it is not stopping it comes on when u turn it on what should i do
Are you getting a high pitch screaming or a grinding noise? The Fan on the heatsink sometimes getting clogged with dust and over time this can cause the computer to turn itself off. Dependant on a high pitch scream this could be a number of problems, memory modules loose or faulty?? Would need more info about the type of sound..
Nov 07, 2009 | Medion md40298 Notebook
High pitched car sounds
does the noise and light occour at the same time ? another cause of a high pitched noise can be slipping drive belts, alternator,powersteering etc so check them for tightness, condition etc, does the noise happen when car staionary and just rev the engine ? if so i would say it is the drive belt/s, go back to the VW dealer re the ABS light and get them to check the OBD as should be done as part of the service , hope this helps
Mar 29, 2017 | 2001 Volkswagen Jetta TDI
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
