Question about Hmdx JAM Party Wireless Stereo Speaker
Hmdx Jam party wireless speaker power light stays on and the unit will not work, was charging the speaker and now it will not turn on, wont make any sound. Any Ideas??
Red light stays on and my bluetooth jam party Red light stays on and my bluetooth jam party hdmxhx-p730gy speaker don't turn on or off
mine has the same problem and i feel as if its the lithium batterie inside that has died and needs replaced. the only problem is i cant find how to open
update: i opened it but i had to break the side open. this is the batteries inside that needs replaced you can get them for about $1.50 on http://bit.ly/1MnbgeD
be sure not to accidentally buy them in balk81aa5f61-0b97-48de-b0e8-6de249df548e.jpg
Oct 23, 2015 | Hmdx JAM Party Wireless Stereo Speaker
Red light stays on and speaker doesn't work
That can mean either two things, either the speaker itself is not making a connection somewhere, or the light is touching a wire that it shouldn't. Now to fix it I would take it to your local audio pro shop and have them fix it. I hope this was helpful!
Oct 21, 2015 | Hmdx JAM Party Wireless Stereo Speaker
Can I pair my jam wireless speaker with my IPod Nano 7th generation?
no because the speaker wont connect or show on any ipods except forr the ipod touch
Feb 17, 2015 | Hmdx Jam Plus Wireless Speaker for Most...
How do I charge a HMDX Bluetooth speaker
Unit should have come with a usb cable. If it did not, look at what type of connector is on the speaker,(mini usb), or take the unit to your local electronics store (Radio Shack) and have them help you find the proper cable or power supply, you should be able to plug your speaker into the USB port on your computer which will then charge the batteries (if they are recharable)
Feb 15, 2015 | Hmdx Rave Bluetooth Stereo Speaker
My jam classic wont go into pairing mode at all and my phone wont pick upat all
Make sure your Bluetooth is turned on on your phone. You may have to make it discoverable as well
Feb 09, 2015 | HMDX Audio JAM Bluetooth Wireless Speaker...
How do I take apart an hmdx jam speaker?
The video shows how to disassemble hmdx jam speaker.
Nov 20, 2014 | HMDX Audio JAM Bluetooth Wireless Speaker...
Jam wireless speaker will not work
That is more than likely faulty wiring, or something is lose, if it is faulty wiring the only thing I can say is Take out the speaker and trash the rest of it, if something is lose then find the wire that's lose and re - solder it. If it is a lose wire it is more than likely the power wire, cause when power is being sent it is being sent such a fast speed that it will jump to (wire B) before stopping at the end of (wire A)! I hope this was helpful!
Apr 17, 2014 | Hmdx Jam Wireless Portable Speaker for...
Want to use a wireless speaker via bluetooth. How do u turn on the bluetooth? I push the FN, and F3 and get 'no device'. I need to 'pair' the speaker (HMDX Jam Wireless). Well, help
Does you laptop have Bluetooth? Open start menu, search, type Buletooth, Does it come up? OR, Open Device Manager, Network Adapters, is Bluetooth adapter listed? OR, Open Services, do you see Bluetooth? If you find the Bluetooth Software, open Settings.
Feb 06, 2013 | Acer Aspire One PC Notebook
HMDX Jam wireless speaker cannot be paired with my computer
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
Feb 02, 2013 | Audio Players & Recorders
Hmdx JAM Party Wireless Stereo Speaker Logo
364 people viewed this question
Top Hmdx Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hmdx Audio Player and Recorder Expert? Answer questions, earn points and help others
