Question about Dell Studio 15 Laptop
Bios boot 1555
Failed diagnostics test error code 2000-0142
  • Erin Clark
    Erin Clark Nov 25, 2013
    Ill just go get a new one, I have a full back up on my external hard drive, for once i am prepared!! woo! Thanks for your help :)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
That error is a hard drive error. My suggestion is to possibly get a new hard drive.
Posted on Nov 26, 2013
Geekman
  • 32281 Answers
SOURCE: D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Feb 17, 2009
parrotheadpc
  • 2600 Answers
SOURCE: My Dell Latitude D830 will not boot up?
Your boot up needs to be repaired...follow the following repair and you should get booted back up. I do believe however that you are losing your hard drive, so watch it carefully and think about getting a backup for your files.
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 12, 2009
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
bschilz
  • 2049 Answers
SOURCE: Dell Inspiron 1521 Error Code 2000-0146
It means "DST Log contains previous error(s)."
Dell Support says “If the diagnostic test reports one of the above errors, refer to Dell Troubleshooting Wizard: "Hard Drive Fails the Diagnostics" Wizard ID: 324398”
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=79E54961218510CBE040AE0AB5E158B6&treeid=324398
Posted on Dec 05, 2009
Testimonial: "Thank you for your help. I don't know what you mean about the thumbs up; I just logged into my account for the first time today and rated you..."
  • 3940 Answers
SOURCE: i get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
I get the error code 2000-0146 only when i run the f12 diagnostic
Dec 11, 2009 | Dell Computers & Internet
Dec 05, 2009 | Dell Inspiron 1521 Notebook
Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
Sep 07, 2009 | Dell Dimension 3100 PC Desktop
Error Code in Diagnostic 1000-0146 BUT MY COMPUTER WORKS?????
The 1000-0146 is a diagnostic result indicating a failing hard drive. Just because the drive fails diagnostics, doesn't mean it will not function and is may run for an extended period before if becomes unusable. But take this as a warning and backup any important data you have on that drive NOW.
As far as your PCMCIA Card slot not working.
  1. Ensure it is enabled in the BIOS and you have no driver errors in Device Manager.
  2. If those all check out, replace the card cage: http://cgi.ebay.com/DELL-LATITUDE-D600-PCMCIA-SLOT-CAGE-CMD3BE7632_W0QQitemZ280331231481QQcmdZViewItemQQptZLaptops_Nov05?hash=item280331231481&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Apr 13, 2009 | Dell Latitude D600 Notebook
BIOHD-5
hello there
depending on the error code it is hard to determine what the problem is
but here is a link that should cover almost all of the codes
  1. C H a P T E R 1 - Troubleshooting Tools POST diagnostic and error message reports are displayed on a console. ... 0) Tests Failed:0 Elapsed Time: 0:0:0:25 If you specify a path argument to test ...www.scribd.com/doc/16604965/C-H-a-P-T-E-R-1-Troubleshooting-Tools - 94k - Cached
Mar 25, 2009 | Compaq Computers & Internet
How to fix Hp slimline Error Code BIOHD-5
1. Restart the computer.
2. Keep tapping the F10 key when the Compaq logo appears. BIOS Setup Utility.
3. Select the Diagnostic tab.
4. Select the "hard drive self test" option and press enter to perform the test. Note: This test takes atleast 40 minutes. This will take you to
Pass - The hard drive is not damaged.
Fail - The hard drive is damaged and may need to be replaced.
Mar 09, 2009 | Computers & Internet
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Error Code: 1000-0146
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
Dell Studio 15 Laptop Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
