Question about Vizio SV420M LCD TV
Is my vizio cec compatible
If it is how do I enable it?
How can I control a vizio blue ray player without the remote?
If you are connected to the tv with hdmi cable theres a good chance the tv has a setting called hdmi cec. if you click on that the tv will take over control of the blueray and the tv remote will operate it using the xtra keypad with usual play,ff,rew buttons.
Aug 16, 2017 | Vizio Televison & Video
Add dvd to vizio smart tv
chechk ou ece or cec settings
Dec 28, 2016 | Vizio Televison & Video
Vizio LED TV E48-C2 keeps turning on by itself.
Turn it off and on using the power point. You will also save power as equipment still uses power in standby mode.
Aug 01, 2016 | Vizio Televison & Video
Can a Box Switch Record Logs and Alarms After a Loop Detection-enabled Interface Detects a Loop?
A fixed switch (such as S2309TP-EI-DC) can record alarms but not logs after a loop detection-enabled interface detects a loop. The configurations are as follows:
In V100R005 and V100R006, you can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection. If snmp-agent trap enable has been configured globally, the alarm function has been enabled.
Loop detection and loopback detection have been available since V200R001. You can run the snmp-agent trap enable feature-name ldttrap command to enable the alarm function for loop detection and run the snmp-agent trap enable feature-name lbdt command to enable the alarm function for loopback detection.
You can run the display trapbuffer command to view alarms.
Jul 18, 2016 | Computers & Internet
How do the hmi on tv withe control
How to Enable HDMI-CEC on Your TV, and Why You Should
www.howtogeek.com/.../how-to-enable-hdmi-cec-on-your-tv-and-why-...
Jan 16, 2015 - The devices can have some control over the TV, and the TV can have some control over ... AOC: E-link; Hitachi: HDMI-CEC (Thank you, Hitachi!) ...
How to find out if your device is HDMI CEC capable?
hdmicec.blogspot.com/.../how-to-find-out-if-your-device-is-hdmi.html
May 18, 2012 - Hitachi - HDMI-CEC ... You can control your computer with your TV'sremote control and you can set up that your laptop shuts down or goes to ...
[PDF]OG S606 U516 Eng - Hitachi Service
Dec 26, 2015 | Hitachi Gst Hitachi 46" Class LED-LCD...
Why does it turn on, then off?
"HDMI-CEC", short for HDMI Consumer Electronics Control, is an HDMI feature many TVs and peripherals have.
If the TV is connected to an HDMI or a programmed remote is being used on the cable box the TV may be getting a second command via the HDMI cable.(CEC) Suggest disconnecting the HDMI cable and manually turning on the TV and see if it will remain on with just a blue screen, Try changing the input to antenna-DVD etc and see if the TV remains on.
You may need to check the settings in the cable box or DVD to change the auto control(CEC) feature. Or if you prefer controlling the TV via the cable box remote then you would not use the TV remote for turning on and off.
This can get very confusing because the TV and the DVD or the TV and the cable box will interact between each other. The problem can be more confusing if the components are not exactly compatible with the CEC. Also many remotes have the additional feature of controlling other components in your AV setup. Many times the operation is alternate action. So each cycle of the remote the TV changes state from on to off. If the two components are out of sync than one is on and the other is off. In that case not using the master on off of the remote but using the individual component setting allows for the two to be sync again. (both off or both on)
Nov 15, 2015 | Sanyo Televison & Video
Where do I find the cec connection for setting timing?
cec.
timing of what, cam or spark.
what engine, is there.
Computerized Engine Control or Computerized Emission Control (CEC)
the 4.0L and 2.5 liter , uses the RENIX ecu. and not the CEC. tje REnix has fixed, CKP sensor timing.
the 4.2liter has distrib timing.
see below.
my guess is you have the instructions and
get lost at the find VACUUM switch on top of valve cover words?
yes?
Jun 28, 2015 | 1988 Jeep Wrangler
Is my Sony Grand Wega Consumer Electronics Control (CEC) compatible?
Consumer Electronics Control (CEC) What is Consumer Electronics Control (CEC)?
Consumer Electronics Control or CEC is a function that allows you to control multiple devices over HDMI using one remote control by having a secondary device receive commands from a primary device. Although CEC wiring is required for every HDMI port it does not mean that every HDMI port will have the function enabled.
If your device has the CEC function, this information will be located under your setup or settings menu.
To enable the function you will need to turn the CEC function on and then search for any devices that are CEC enabled that are connected to the TV.
Was this article helpful? 2 out of 4 found this helpful Have more questions? Submit a request
Related articles
Jun 13, 2015 | Sony Grand WEGA KDF-50WE655 50" Rear...
Inputs change overnight by themselves
If you have CEC enabled, then it may be affected by overnight updates.
Try disabling CEC
Sep 09, 2014 | Televison & Video
Is there a way to turn off the TV and hear music. I have tried but every time I turn off the TV the receiver goes off
What is the source of your music? And how it is connected to the receiver? If via HDMI, then it is not possible. Source HDMI device will not put any audio into the HDMI when the display device is not turned on (it must authentificate with the TV to be sure you are not doing any unauthorized copying).
If your only issue is that when you turn off TV it turns off the receiver, then turn on the receiver only after you have turned off the TV. If this causes the TV to turn on also, you have HDMI CEC enabled. HDMI CEC enabled devices to communicate with each other via HDMI - receiver can tell TV to turn on/off. You can disable the HDMI CEC support in receiver menu if you want. After that, your TV and receiver will turn on/off independently of each other.
Aug 30, 2014 | Yamaha RX-A810 Aventage Audio video AV...
Vizio SV420M LCD TV Logo
166 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
