Question about Jenn-Air Cooktops
Cooktop JED8430ADB Kicking circuit breaker
Breaker is tripped and won't reset
Amigaman
  • 248 Answers
SOURCE: GE JCP 930 Cooktop Wiring
These fuses are under counter? It should be wired to breaker box. Check specs in manual but i suspect a 30 or 40 amp breaker.
Posted on Nov 18, 2007
  • 105 Answers
SOURCE: Loud Pop, blown Breaker
Pull the unit away from the wall and inspect from rear. However, if all is fine, perhaps you simply overloaded the circuit that once. Were you running any other appliances (overhead microwave) at the same time?
Posted on Mar 28, 2008
  • 161 Answers
SOURCE: GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Posted on Jul 15, 2008
SOURCE: my ge ceramic cooktop hot indicator light won't go out
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: stove is tripping circuit breaker
if it is an old stove i would say have it serviced/checked over. if it is a newer stove i am guessing the circuit breaker predates it and is rated for the old stove therefore you will need to have a larger circuit breaker installed (by a licenced electrician)
Posted on Jul 09, 2009
We cleaned to cooktop and now the igniters don't work. the ciruit breaker won't reset and continues to trip
You are short circuiting the cooktop. Make sure no metal is touching the igniters. Check everything again, making sure everything is in place correctly. Also make sure it is fully dry.
Jan 20, 2016 | GE 36 in. JGP628 Gas Cooktop
I have a GE 36" Profile Gas Cooktop JGP963 and when i light one of the burners, it trips the GFCI , main breaker and a little fire ball comes from under the knob. what could cause this?
IT SOUNDS LIKE YOU HAVE A SHORT IN THE IGNITER. YOUR COOKTOP SHOULD BE ON A DEDICATED CIRCUIT AND NOT A GFCI. YOU MIGHT HAVE TWO CIRCUITS TIED INTO THE SAME RUN. POPPING THE GFCI AND THE MAIN BREAKER IS SUSPECT. THE GFCI SHOULD SHUT DOWN THE CIRCUIT WITHOUT POPPING THE MAIN. THIS IS PROBLEM THAT SHOULD BE LOOKED AT BY AND ELECTRITION.
Apr 04, 2013 | GE 36 in. Profile JGP963 Gas Cooktop
Sparking which causes circuit breaker to trip and turn off various power in the kitchen
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Sep 25, 2010 | GE Monogram ZEU36 Electric Cooktop
Breaker in panel tripped and won't turn back on
You may have a short circuit to ground fault in the electric cook top. Divide and conquer. Unplug the cook top and try to reset the breaker. If the breaker resets, then you have a problem with the electric cook top. If it doesn’t, then the problem is at the electrical panel side. Either problem will require a qualified technician’s assistance. I hope this helps. Good luck.
Jul 16, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Electrolux induction cooktop shuts off and won't turn back on
There is an internal thermal circuit breaker. The breaker has gone bad. On-line of Electrolux find a service manual of your model to locate the breakers location. Contact a local appliance parts store for a replacement also ask for heat sink gel(very small amount). Trip the circuit breaker, remove bad one, clean the space, apply gel and replace it.
May 13, 2010 | Cooktops
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
Popping noise and red light
it could be a switch, element or a short somewhere else
Apr 29, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
21 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
