Question about Acer Aspire E1-571-6650 Laptop
Screen Freeze Every time I turn on my laptop it freezes. I can move the mouse but I cannot click on any icons. After about 5 to 10 minutes it usually fixes itself but this is a hassle. How do I fix this?
    Scholar:
  • 174 Answers
Overheating causes laptops to freeze. If you haven't been using a laptop cooler then start using one. Laptops need proper ventilation. If that is not the cause then you might need to re-format your system as there might be important extensions/files that were deleted accidentally or your system might have been invaded by viruses.
Posted on Nov 26, 2013
  • 12 Answers
SOURCE: Weird clicking noise and computer freezes.
Laptops have very few moving parts. Your problem is more than likely either a fan or your hard drive. Remove the hard drive, start the computer up and just let it run for awhile. If the clicking noise never comes up then thats your problem. If it does, its probably a fan.
Disregard anything on the screen itself, just let the PC run. It sounds like after the hard drive has been spinning for a minute a motor starts to die.
Posted on Jan 29, 2009
cheap to fix
  • 404 Answers
SOURCE: Laptop mouse pad acting weird
i think there's a ghost using it! lol
this cant happen i never heard of it, i think theres someone remotely using your laptop and clicking things
Posted on Mar 05, 2009
  • 1019 Answers
SOURCE: Can move the mouse but not clikc with the touchpad
if you installed an external mouse, it would over-ride the touchpad.
try removing the external mouse, and tap the touchpad twice as if you were double clicking it.
also you could try re-installing the touchpad device driver, usually synoptics or similar.
Mike @ compurepair.
Posted on Jun 11, 2009
SOURCE: cursor freezes
YOU MAY WANT TO CHECK THE TEMPERATURE OF THE CPU BUY RANDOMLY REBOOTING AND ENTERING SETUP TO CHECK CPU TEMP IF THE FAN OR CHANNEL ARE NOT ALLOWING AIR FLOW THEN YOU COULD BE SUFFERING FROM A OVERHEAT AND THE SYSTEM LOCKS, HAD A SIMILAR PROBLEM WITH WIFE'S LAPTOP. YOU MAY BE ABLE TO GET MONITORING SOFTWARE FROM THE MAIN COMPANY OF ANY LAPTOP.
Posted on Aug 21, 2009
SteveRand
  • 210 Answers
SOURCE: The mouse on my Acer Aspire 300 laptop has stopped working
You may have disabled it. Fn + F7 or similar.
Posted on Nov 18, 2009
P875 satellite keyboard
Do the key lights flicker when on freeze stage? I had such a problem with my keyboard, it died after around a month :(
Apr 12, 2013 | Computers & Internet
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Why my computer mouse freeze?
what operating system on laptop?
pre windows xp was a common problem I had
turned mouse switch on and off and sometimes regained mouse. switch is usually right by mouse pad to either use pad or external mouse. I am by no means an expert but had problem like that. Also had the dreaded blue screen of death till went to XP and now have windows 7. Well hope that helps some>!!
Mar 16, 2011 | IBM ThinkPad R50e Notebook
Mouse freeze up when i first turn on cp
try to boot in safe mode and check if still freezes. if yes then. boot to f8 select last known good configuration. if fails.try to do system restore using the recovery disc. if fails then before reinstalling OS. try to connect an external mouse first then update antivirus then run a full system scan. if still fails then reinstall. OS.
Oct 24, 2009 | Dell Inspiron 1545 Notebook
Cursor wont move
1.fn key and mouse fn key at same time (f4 f5 f6 )
2.ribbon cable loose from mouse pad to motherboard
3.bad hard drive will freeze then move again, then freeze
Jul 20, 2009 | Acer Computers & Internet
Why does my curor freeze up?
First I would replace the batteries. I had the same problem a couple of years ago. The solution for me was getting rid of McAfee AV. To check if it is your problem, use CTL-ALT DEL to turn McAfee off and see if that gets rid of your mouse freeze ups.
May 24, 2009 | Dell Dimension 3100 PC Desktop
Nascar Cisnet Laptop NCL3006 freezes after I plug in a USB device
sounds like a faulty USB driver - i recommend uninstalling all USB drivers and using drivermax.com to get the correct ones. Your computer may have automatically updated your drivers incorrectly without you knowing.
Hope i could help
CBZ
Comment if you need more assistance
Apr 28, 2009 | ZT Group Cisnet T2060 Notebook Computer
My iBook G4 continues to run slowly and/or freeze
Try resetting the PRAM by turning on the iBook then holding option + command + P + R and wait till u hear another chime. If it still freezes, it may indicate an application may be causing it to lock up hold shift after you hear the chime to boot OS X into safe boot.
Mar 18, 2009 | Apple iBook G4 Mac Notebook
Laptop Freezing up
SOME ASPECT THAT MAY FREEZE YOUR UNIT:
  1. Overstressing the system.
  2. installing too many programs
  3. Contract but fail to detect a virus infection.
Jun 20, 2008 | Computers & Internet
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
Acer Aspire E1-571-6650 Laptop Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
