Question about IBM 38f7290 Monitor
I have a viewsonic monitor and the picture screen does not show the entire picture causing overlaping,how do i resolve this problem. thanks mea
    Sergeant:
    Champion:
  • 255 Answers
Try to adjust the setting on your monitor or you video card.
Posted on May 08, 2009
Hi, I have a ViewSonic VX2235mw LCD Monitor it was working fine then all of a sudden the screen turned off and now it wont turn back on. The power light is on and is Blue but no sign of life in the screen...
This is a very common problem with this model after a few years of use. This problem is caused by a failure of the capacitors in the power supply board hat powers up the back lights in the monitor. When the back lights don't power up you get no display on the screen. Here is a link to a repair guide for that model that shows how to open the unit and what to look for and replace to repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Here is part one of the three part video repair guide posted at the above link:
Jan 29, 2013 | ViewSonic VX2235wm LCD Monitor
No power to vx2235wm. How can I fix it?
Black screens or no pictures are usually caused by a failure in the back light power supply. Many times the monitor is working but with the back lights not turning on you can't see the display. Here is a link to a repair guide that will show you how to open the unit and what to look for and replace to rebuild the power supply and bring the unit back to life.
I hope this helps, if so please rate my solution.
BuddyMc
Dec 07, 2011 | ViewSonic VX2235WM Monitor
How to open a viewsonic vx2235wm monitor?
Here is a link to a repair guide with pictures and videos showing how to open the unit and then repair the power supply board that is the most common cause of issues in the VX2235wm monitor.
BuddyMc
Nov 14, 2010 | ViewSonic VX2235wm LCD Monitor
Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
May 24, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
Monitor flashes on then off power light stays on whats wrong?? shows screen for about 3 seconds then goes black
Some 22" Viewsonics will have worn out bulging capacitors in the power supply that causes this symptom.
Monitor Mike
Apr 14, 2010 | ViewSonic 22" FLAT SCREEN CRT BLACK...
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Lines?
If this is a new to you monitor, then you may need to update the video driver for this model. You can do that online from Viewsonic's website.
Good luck, and let me know if you are able to fix the problem, or provide more info!
Jan 01, 2008 | ViewSonic VA1912w 19" LCD Monitor
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Computers & Internet Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
