Question about Air Tools & Compressors
When it sits for awhile it has a hard time starting and it makes a loud backfiring noise
    Sergeant:
    Champion:
  • 255 Answers
Check the valves
Posted on May 08, 2009
MY 29 DFI KAWASAKI MOTOR BACKFIRES WHEN TRYING TO START
Once you get it started and warmed up, do a timing check with a timing light. It sounds to me like the timing is too far advanced and that causes the backfire when trying to start but will run fine when warm. Over-advance can cause pre-detonation at the plug and can burn a hole in the top of your piston, even though it runs fine. Reset your timing.
Nov 11, 2017 | Cars & Trucks
1983 Honda Shadow 750 that backfires once in awhile when starting. Any ideas?
I have a 83 Sabre V45 which had the same problem. I removed the top covers of all carburators, and found 1 diaphragm had a hole in it. I replaced it, and everything worked fine. Hope this helps.
Apr 16, 2013 | Motorcycles
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Griddle makes backfire noise
I get the same sound but I found it is actually coming from my stainless steel backsplash, it seems like the heat makes it flex from time to time.
Jul 10, 2010 | Viking VGIC485-6G Gas Kitchen Range
Started up gaggia classic for the 1st time today. followed the instructions in the manual but when switching on the pump, it made ery loud noise and no hot water or steam apeared through the nozzle or...
You need to let this happen for awhile until the pump "primes" or fills all the way with water. Let the it run with the noise for awhile. Also, let it sit for at least 20 minutes before you start running the pump.
Nov 21, 2009 | Gaggia Classic Espresso Machine
Starting
There are many reason why your car wont start.
Check Your Fuses
Battery Issue
Bad Igntion Switch
Bad Starter Connection
Test your ignition coil
Just go through these two link
http://www.ehow.com/video_112584_troubleshoot-car-wont.html
http://autorepair.about.com/od/troubleshooting/a/ts_no-start.htm
Hope these links will help
Let me know
Thanks
Kindly rate the answer
Smith
Jul 09, 2009 | 1999 Dodge Intrepid
Sluggish loss of power and popping noises from engine
Clean the distributer cap in the inside, it has water in it thus causing all the noises and the back fire.
Jun 20, 2009 | 1994 Volkswagen Golf
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
95 jeep grand cherokee, hard starting, backfires, when cold
get a couple bottles of gas line antifreeze .. if you don't already use it and add it to the gas.
Robert
P.S. in minus 40 i don't even get out of bed... minus 23 here last nite... isn't winter grand
Jan 21, 2009 | 1995 Jeep Grand Cherokee
Maxtor hard drive
if it stops and after some time it stop making noise then it means its having problem with the magnetic plates so i suggest you to change the drive.
maxtor drives are very sensitive to shocks may be it get a shock.
Jan 16, 2008 | Maxtor Hard Drive
Air Tools & Compressors Logo
63 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
