Question about Maytag Neptune FAV6800AW Top Load Washer
Pulley Came off!!!
My gilfriends Maytag Neptune TL Washer made a horrible noise last night...i got home tonight and opened it up and found the belt off the motor and the pulley and the darn pulley was laying on the bottom...i found the 'small' bolt that holds the pulley on so i 'did my best' to get my hands under there (only like 2 inches work with...I was able to get a wrench on ti and tighten it down...but during a test spin cycle, it made some noise and came off again...the manual asks for 96lb of torque but i dont have torque wrench (plus i would not be able to fit it anywayy....anyway, i tighted the bolt on tighter the second time...and ran the spin...but the motor would not run....ended up getting a LR value on control panel...if i dont tighten the bolt tight, it comes off..if i tighten it too tight, do you think that is what is causing the motor to freeze up (or at least not pull the belt enough to spin pulley?
    Sergeant:
    Champion:
  • 255 Answers
Pull the belt enough to spin pulley.use extension for you tools
Posted on May 08, 2009
  • 335 Answers
That’s 96inch pounds 8 foot pounds just make it snug. If you are still having issues with the clutch pulley see this post.
Posted on May 09, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load washer is sounds like it is out of balance when spinning. Very loud noise banging noise. Opened the back and found a silt material left over from a liquide leak. The materials...
yes there is a kit these are failing left and right. this unit is the reason maytag doesn't exist anymore (whirlpool bought them out last year) if everything else is okay you can do this repair but it is expensive to have someone else do it
May 10, 2008 | Washing Machines
Neptune washer will not extrACT water
Not belt or pulley!
Pump located below drum blocked or filter blocked
May 01, 2012 | Maytag Neptune MAH5500B Front Load Washer
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Work fine but when spin mode makes a lot of noise (CLICKING SOUND)
More than likely a Clutch issue. Google this Google these text phrases for support Sticky: Neptune TL Washer FAV6800AWW to the 5th post down in that Sticky. I go thru how to remove the Clutch Pulley and inspect for wash water damage caused by a leaky Tub Seal.
I will help you on that forum if you want to DIY. Go to the Maytag/Magic Chef/Admiral/Jenn-Air forum and post your issue for help. I check it every day for FAV6800A and FAV9800A issues.
Aug 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
GETTING DC ERROR CODE WITH A GRINDING SOUND AND THEN IT STOPS COMPLETELY
The DC error code is 9 time out of 10 caused by a Clutch Pulley malfunction. The grinding may ne Outer Tub Bearings but need more info. Open the Washer Lid. Spin the wash basket CCW. Do you hear and grinding noise?
The noise may be coming from under neath the tumblers. Further troubleshooting is required.
Do you have basic DIY mech. skills and do you want to save your $1K machine?
If so Google Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
Good luck.
Mar 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Trying to remove clutch/pulley bolt on Maytag neptune tl washer. Turning bolt only makes pulley spin. Which is correct direction to turn it when looking up at bolt head? Some posts I read say CW (left...
It's std thread place your 3/8" socket wrench at three o'clock position on the bolt....the handle pointing to the right side panel. Hold the Clutch Pulley with your left hand and pull toward you. This is CW rotation of the socket wrench toward the front of the machine. You have to hold the Clutch Pulley from turning. leave the drive belt on. It's right Hand thread I tried to describe CW rotation of the bolt to loosen.
My last post here good luck.... Sorry if I caused any confusion with this post Clutch repair post
Sep 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL Stops
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Sep 24, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
185 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
