Question about Toshiba DVR670/DVR670KU DVD/VHS Recorder with Built in Tuner, Black
Toshiba DVR670KU power will not stay on
Push power on and unit powers down almost immediately. After a few tries, it won't power on at all.
SOURCE: toshiba md20p1c tv power won't stay on
The problem is Q401. Change it. It is a 2SC1624 but a 2SC1018 will also work. This solution will work for other Toshiba P combo units.
Posted on Mar 14, 2008
  • 3 Answers
SOURCE: Toshiba 27A51 TV won't power up, relay clicks twice
must be some of parts broken down. you have to check powersupply thorougly.
Posted on Feb 04, 2009
md_ehsan_1
  • 255 Answers
SOURCE: When I power 0n it shuts down immediately
sometime some keys are pressed, check your keyboard
Posted on Jun 28, 2009
  • 36 Answers
SOURCE: Hi my toshiba L455-S5045 won't power on, I've
This clearly shows that you have a defective motherboard and it needs to be replaced. Try contacting Toshiba support for this, hope this computer is still under warranty.
Posted on Jul 01, 2011
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Posted on Jul 16, 2011
My sharp aquos won't power on
CHANGE IC202 WITH TL431 OR TRY PUSH INPUT AND VOLUME DOWN THEN PLUG THE POWER UNTIL THE GREEN LIGHT START ,,, WHEN IT START PUSH VOL DOWN AND CHANNEL DOWN AT THE SAME TIME AND PLAY WITH THE SETTING
Apr 20, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My immediate 2426keeps rebooting but does not come on
Does it turn on for a few seconds and shut down? That sounds like a PSU failure. Try reseating the Memory mods, or remove 1 then the other, swap. Replace the CMOS battery. When you push the on/off button, it stays powered up? But does not boot? HDD spins? LED's blink?
Dec 25, 2012 | Packard Bell iMedia 6826 (P481000502) PC...
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
Boiler pilot light won't stay lit
Power can be on just turn the room thermostat down .
Apr 06, 2017 | Burnham IN5S-SP-EZ-NG IN5, 86,000 BTU...
My msntv2 won't power up. A green screen comes up and says refer to error code #131.
I got the same problem a few days ago error#131 on my msntv2 unit. Tech support at msn said to start with the power on ---then push and hold (alt) and push power and release both at the same time and the power should shut off.--- Then push and release Power and Immediately push and hold down (alt.)---Then a Orange light should come on---Then release the (alt) key--- then enter 5532 5532. If that does'nt work then try starting with the power off---Then push the OK button 3 times then push 5532 5532. Mine didnt work so I dont know what happens after that. Good luck
Apr 30, 2012 | RCA MSN TV 2 Digital Media Streamer...
I need to obtain an owners manual for a Toshiba DVR670/DVR670KU DVD/VHS Recorderwith built in Tuner
Hello larry strunk,
if you click on the website below, it will take you to a website where you can download the manual. Just scroll down and you will a owner's manual in a pdf format.
http://www.helpowl.com/manuals/Toshiba/DVR670/10589
Good luck,
Joe
Aug 26, 2011 | Toshiba Televison & Video
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
Feb 07, 2011 | Microsoft Windows XP Professional
Can not get the power button to shut down the computer no matter how long I hold it down and the computer appears to stay in hibernation. Will not reboot or do anything when power is applied and power...
Remove the battery and leave off for about 1 minute. Put the battery back in place and press the power button to turn the unit on. immediately after you see system light come on, press and hold the power button and see if it shuts off after a few seconds. If not, then its likely your motherboard is defective.
Sep 07, 2010 | Toshiba Satellite M100 Notebook
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Toshiba DVR670/DVR670KU DVD/VHS Recorder with Built in Tuner, Black Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
