Question about Sony TA-N9000ES 5-Channel Amplifier
Sony F410R no souund - Sony TA-N9000ES 5-Channel Amplifier
Why souund goes to max
Memory chip on the main board needs to be replaced.
May 12, 2015 | Samsung Televison & Video
Marantz 7300 pcm flashing no audio
Try upgrading your firmware and do a reset on the receiver. If this does not help your problem, then you might have an HDMI issue or a bad DSP chip.
Aug 02, 2012 | Audio Players & Recorders
Car when gets wet steering wheel freezes up
souunds like your a/c compressor is locking up if it only does it when you turn the a/c on
Jul 07, 2012 | 2006 Kia Optima
I have two JBL speakers each 100W and 400W(peak) connected to sony receiver 7 ch each suppoert 110W connect to Karoak with 2 microphones but to sing souunded not good. thinking to get this 250 W PA amp or...
You haven't sufficiently defined what is wrong. "Not good" is subjective. Before you shell out for different hardware you should pinpoint the problem.
The source (you, mics) and the speakers are the most obvious sources of sound quality issues. Properly functioning amplifiers operated within their limits produce effectively undetectable differences in the sound.
Feedback from the speakers to the mics will sound awful.
Jul 07, 2011 | Radio Shack 250 Watt PA Amplifier...
I have a Sony KP-48S35, Rear Projection TV and the picture goes on and off but the audio works fine. When I first turn the TV on, it takes around minutes for the picture to even come on.Which meens for...
i would say the bulb is on its way out and needs changing. on the back there is a hatch with one screw remove the screw and unclip the bulb holder, then pull out by the handle part number is on the bulb housing or the tv case.
May 23, 2017 | Sony KP-48S35 48" Rear Projection...
I have a SONY amplifier, TA-F410R. When I turn it on I hear nothing. Only after I boost te volume (generally per speaker) does the amplifier burst open. If I choose not to pump up the volume, I can also...
My 1st thought would be the main power supply capacitors.
If they are dried out or "leaky" they WILL take a long time b4 the power supply gets up to where it will run the amp
Get the main capacitors replaced
Nov 02, 2010 | Sony Audio Players & Recorders
No display after on the tv
check horizontal transistor , if it is ok check the regulators 5v and 9v , check all diodes at the secondary side of the power supply
good luck
abebe
May 11, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My sound is all wacked
well something might be stuck in the psp and thepsp might think its headfones and wont make the sound go outloud.see if ther is anything in the psp souund hole wer the sound plug is
Feb 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony TA-N9000ES 5-Channel Amplifier Logo
35 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
