Question about eMachines Computers & Internet
Hdmi 1 or 2
How do I hook I up to my tv
    Top Expert:
  • 12,223 Answers
See the diagram attached, and proceed . God bless you
Posted on Nov 26, 2013
Can i hook up a seiki model SE39UY04 to a comcast HD box useing only the HDMI cable and which slot on the TV do I use
You should be able to. You should be able to hook the HDMI cable into the tv, than go to "TV Input" and select "HDMI 1" "HDMI 2" or "HDMI 3" depending on which input you used
Nov 30, 2014 | Seiki 39" Class 4K 120Hz LED Ultra HDTV -...
Computer wont detect hdmi1 on tv
HDMI 1 and 2 are physical sockets. If you need it on HDMI 1, plug it into the HDMI 1 socket.
Feb 27, 2014 | Computers & Internet
LED TV takes 7-13 mins to display a picture when hooked up to cable DVR box, when hooked up w/ out DVR Does Not do that???
I would suggest you verify your cabling. Are you using HDMI cables? Connect a HDMI cable from the TV HDMI 1 to the Cable DVR Box, In the TV setup ,select HDMI 1 as source. If your Cable box does not have HDMI contact the provider for a updated box. With out the Make, Model of Box, Cable? Sat? Make, Model of TV. I don't know the connections?
Jan 26, 2013 | Televison & Video
I want to know how to hook up my PC to this TV as a monitor. The manual says to use HDMI 1 port and the DVI port on PC. Do i need to get adapters to make such a connection
an hdmi cable will do then hook up to hdmi port 1 and on tv select that input and it should work. of course the hdmi cable has to be hooked up to hdmi input on computer
Jul 08, 2012 | Magnavox 32MF339B 32 in. TV
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I have plugged my hdmi cable to both tv and ps3 but it says no signal???
hi,
Welcome to fixya! here's the thing with this no signal issue on your TV hooked up on an HDMI try to double check physical conenction and make sure your on the right input, say for ezample if it is hooked on HDMI 1 input should be set as well on HDMI 1.
Hope this would help you
Thanks
Apr 12, 2011 | Daewoo DLN17D3 Television
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
I just brought a plasma tv and how do I hook up my cable tv and ps3 to it?
standard cable, just hook it to ant 1 or 2...your ps3 should have an hdmi connection, looks like an oversized usb cord. hook your ps3 into hdmi 1 or 2 or 3, doesn't matter. then switch your inputs on the tv accordingly.
Jul 11, 2008 | Panasonic Televison & Video
Computers & Internet Logo
14 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
