Question about Garmin n?vi 260 Car GPS Receiver
I just received a Garmin Nuvi 260 as a gift, yet when I turn it on, it said that the screen is locked and that I need to slide the power button to the left to unlock it. But, when I did so, it still displayed that message.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Did you try touching the screen after you moved it to the left?
    - Jim
    SHARCNET-USA
  • Garmin Expert
  • 343 Answers
Make sure the battery is fully charged.
The on / off button is spring loaded. After pushing to the left it should spring back to the middle
Posted on Feb 24, 2010
I dropped my Garming Nuvi 260 this past weekend and when I turn it on it goes to a screen saying Updating GPS Firmware 1% then jumps to Updating GPS Firmware Complete. It keeps popping up with these...
Inspect the bottom of your Nuvi 260. According to the owner's manual, some models have a small "Reset" button on the bottom. If yours does, you'll use this to reset the Nuvi 260.Press and hold the "Reset" button for several seconds, until the Nuvi powers off and powers back on. Next try
to slide the power switch on top all the way to the left to reset your Nuvi if it does not have a "Reset" button. Performing this action resets the system.
Next try a hard reset.
Slide the power switch to "Off."
Press your finger against the screen in the lower-right corner. Hold your finger in this position.
Slide the power switch to "On" to turn the Nuvi on. Continue holding your finger on the screen until the pop-up window appears. When it does, press "Yes" to reset your Nuvi to its factory settings.
Hope this works but dropping may have caused internal damage. If this does not work you may have to send it back to Garmin for service. I will attach a link for Garmin. Thanks for using FixYa.
http://www.garmin.com/garmin/cms/site/us/support/
May 30, 2011 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260 touch screen does not respond
Hi
Try and reset the unit by using a straightened paper clip, or something similar, to push the reset button for 15 seconds. The reset button is located near the power hole for docking base. If the reset won't work then the touch screen should be replaced as it is bad. Hope this helps... Please post back if you need more information.
Daniel
Jan 18, 2011 | Garmin nuvi 260W GPS Receiver
Touch screen on my garmin nuvi 205 stopped responding
If the touch screen is not working properly, calibrate the touch screen.
Turn Nuvi off and then back on.
Slide power key to the right (lock). Hold your finger on the screen for about 30 seconds until the calibration screen appears.
Follow the directions on screen instructions
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Nuvi 660 screen locked
I HAVE THE 205 UNIT MY LOCK IS ON THE POWER BUTTON SLIDE IT TO THE RIGHT IT LOCKS AND PUT IT IN CENTER TO UNLOCK - YOURS SHOULD BE CLOSE TO THAT - HOPE IT HELPS
May 09, 2010 | Garmin Nuvi 660 GPS Receiver
I recieve a garmin as a gift @ it now has a code lock on it how can i unlock my garmin 260
The Garmin Lock is a theft-deterrent system that locks your nuvi. Each time you turn the on the nuvi, you would have to enter the PIN or drive to the security location. (where it was orig programmed)
To set the Garmin Lock on the device:
  1. From the Main Menu, touch the Wrench (Tools) icon.
  2. Touch Settings.
  3. Touch Security. (you may need to touch the down arrow button)
  4. Touch the tab labeled Off next to the Garmin Lock heading.
  5. The nuvi will prompt you to enter a four-digit pin number.
  6. Enter a four-digit code as your pin.
  7. Re-enter the four-digit pin.
  8. Go to a 'Security Location' and let the unit acquire satellites (the security location will unlock the unit if the pin is forgotten or lost).
  9. Set the 'Security Location' by touching Set.
The Garmin Lock has now been turned On.
Nov 08, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 250w slide on/off/lock button broken
you going to have to replace it or beg garmin to accept it for repair/warranty.
Oct 03, 2009 | Garmin nuvi 250W GPS Receiver
How do I lock the screen on the Garmin nuvi 500? (not lock the device--just the screen)
on the power switch you should see a slide where you slide it to the right. This will put it in safe mode operation, meaning you cannot touch the buttons until you are stopped. If you do not have the slide switch and you have the push button switch, then navigate to tools/settings/security. You will have two options, the first one is garmin lock, don't worry about this one. Look at the other one, it says safe mode. turn this on. The screen will only be locked as long as you're moving. When you stop, it will not be locked anymore until you start moving again. If you touch the screen while moving, it will ask you if you want to turn safe mode off. Hope this helps.
Aug 25, 2009 | Garmin nuvi 500 GPS Receiver
Brand New...Can't get it to stay on?
Make sure you have it connected to a power source properly. Push and release the power switch. (it is spring loaded) Don't push it to the lock position for now.
Jun 07, 2009 | Garmin nuvi 260W GPS Receiver
I have got a nuvi 260 and it wont come on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
New Garmin 260 W won't do anything when plugged in.
The Garmin doesn't need to plug into anything to work normally.  Just turn it on!
Dec 26, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin n?vi 260 Car GPS Receiver Logo
70 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
