Question about Microsoft Xbox 360 Console
Xbox 360 possibly overheating?
Heres how it goes. I turn on my xbox. It gets to the dashboard, i let it just sit for a couple minutes and it freezes/graphic bug. i took it apart and put new paste on the chips and stuff, didnt help so far. I get no red lights, i am all 4 green all the time. The first time i turn it on, it stays on for 2--4 minutes, the times after the first one decrease, which leads me to believe that it is a heat problem. Anyone ran into this before?
    Novelist:
  • 174 Answers
You can attach an intercooler at the back of the 360 and this will help keep cool
you will also need to do something called a reflow, we us a proper infra red reflow over which in turn re-seats the solder and rectifies these sorts of problems. if you simply just put some paste on your not solving the problem.
once reflowed the machine should work tip top again
if you run a search on google you should be able to find guides on reflowing your mainboard and it is possible to use a heatgun BUT is not so reliable.
regards
FixMyConsole.
Posted on May 08, 2009
Screen went black but sound stayed
Your Xbox Rims In Xbox ARE NOT WORKING.
May 16, 2013 | Microsoft Xbox 360 Console
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
My xbox will not turn on
Yes this is the overheating problem you need to stop the heat build up you can use a good guide or send it in to get it fixed.
Jul 15, 2010 | Microsoft Xbox 360 Console
Vertical black lines...
maybe thats because your COD 4 game is messed up and may need to get another one
Jul 29, 2009 | Microsoft Xbox 360 Console
My XBOX 360 has a Sound but no picture issue.
Well the main solution that you're going to get from Microsoft is to unplug everything from your console and your TV and then wait a couple minutes and plug it back in while everything is off. If the problem still persists, instead of buying a new 360, try borrowing a friend's AV cable and see if that works. Try not to unplug or replug anything while the console or TV is still on. Or it could just possibly be all of the jostling around in your suitcase and nothing has come loose enough to stop working until now. Sorry I can't be more helpful, these are just some ideas.
Jan 09, 2009 | Microsoft Xbox 360 Console
My xbox live doesnt work
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
Games Are Freezing
this has happened to me...
i was first getting red ring of death
then i fixed it and never got RROD again
but it started freezing during gameplay, then at dashboard and then at the beginning until it couldnt start at all...
this can be cause by overheating GPU and CPU causing them to bend and lose connection...just like RROD, or it can possibly be that component that reads and plays games, is screwed up...
Nov 11, 2008 | Microsoft Xbox 360 Console
XB360 Screen colour changes and then disappears
Could possible be your television.
Or maybe your Xbox is overheating.
Try placing your Xbox in a cool spot, direct a fan at it, etc.
Or try getting a new TV or Xbox.
Jun 29, 2008 | Microsoft Xbox 360 Console
3red flashing lights
Hey Tafari, It's an overheating issue that is common in xbox 360 models made between a certain date range. I had the same problem a few months ago.
All you gotta do is contact Microsoft tech support and provide them with your serial number. They'll ask you a couple of questions and then they'll get you to ship them the 360. (They pay for shipping)
They'll try to repair it, but if your lucky like me, you might get a new xbox 360 with 1 month of xbox live for free.
Hope this helps. Worked for me, should work for you.
- klassiq
Nov 25, 2007 | Microsoft Xbox 360 Console
Xbox 360 crashing every 5 minutes !!!!!
mine did the same thing until i turned it on its side so it sits flat on the shelf.try that
Aug 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
