Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Hook up water line and water is coming from the bottom
    Champion:
    Habit-Forming:
  • 279 Answers
Check your connections again.
Posted on Nov 29, 2013
What is wrong when I put it in the water and the water comes out the bottom and not the top
I believe that you are hooking your vacuum line to the filter systems output. Hook it to the filter systems input (suction side).
Jul 16, 2015 | Pool & Spa
Water not coming out of front dispenser
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 02, 2010 | Hotpoint Refrigerators
Water dispenser just stopped dispensing water? Have changed filter only 3-4 weeks ago - any suggestions
Nov 18, 2009 | Whirlpool Refrigerators
Never hooked up one green line running bottom to top with plastic nuts . one valve at bottom looks like a tire valve stem. is this the inlet water line hookup
Do not hook water to the "tire valve stem"! That is probably a freon access valve. Hooking water to that will ruin the refrigeration system.
Oct 31, 2009 | Freezers
There is water leaking at the back of the fridge. Water line is not hooked up. Put a container under it so it doesn't run over my shelves
if there is water leaking, and the water line is not hooked up you have a defrost drain issue
take off the back
find the tube that come out of the bottom make sure it is in the pan near the compressor, and that that pan does not have a hole
you may need to use a few cups of water on the pan
Oct 13, 2009 | Refrigerators
GE GSS25LGMF Water dispenser-no water
Order and install a WR49X10173 water tube heater. It may take 24 hours to then thaw, but it has worked for me on numerous refrigerators. Cost for the part will run about $50.
Feb 07, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
How to install a water line to a Samsung Refrigerator?
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Jan 11, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Water is not coming out of the dispenser and there is a leakage somewhere as ice is forming at the bottom of the inside of the fridge
I know this isn't what you wanna hear but you're going to need a plumber to come out and fix that. It sounds like you're water is hooked to the freon line and your freon is hooked to your water line. If it's been hooked up for a while it's probably from when it was moved/bumped/pulled out, and the line got a kink in it and is leaking at the kink. If that's the case...you'll have to buy an at least 12' long 3/8"or1/4"CLEAR PLASTIC hose (your local hardware store or plumber supply should carry it) either way call a plumber to install, that freon is nasty stuff (poisonous)
Aug 28, 2008 | Whirlpool Refrigerators
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
41 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
