Question about Keurig Platinum B70 Coffee Maker
How do I reprogram my platinum Keurig so it does not shut off
How do I program my Keurig Platinum B70 coffee maker so it does not shut off and how do I choose the cup size
    New Friend:
When I had to turn mine off because someone accidentally turned it on these were the steps.
first select menu and click until you get to the auto off or the auto on/off feature
in the auto off feature you just click the flashing button until is states off.
in the auto on/off feature make sure your minutes are at zero and then click the hour button until it states off. Repeat if necessary on the second part then you should be all set.
Posted on Jan 11, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
With unit powered on, Select Menu button, scroll down, and turn "auto off" to off selection. Cup size is selected after you put K Cup in. The display should flash on a default (1 of 5) cup sizes. You can manually change to the size you want. Alternatively, you can select the Menu button and change the default cup size (same process as stated above).
Posted on Jan 06, 2014
  • 25 Answers
SOURCE: Platinum will not prime.
How long did you wait? It should start up and draw water right away.
Posted on May 14, 2009
SOURCE: I have a platinum Keurig coffee maker. I descale
Dear Rschles2,
I too own a Keurig Platinim.. I haven't a solution for your problem but I can tell you that your description of it is right on... I have had the same problem. Every month or two, my Keurig will decide I need a large cup rather than the size I chose. I've found no way to solve it... even unplugging the machine doesn't help. In the end, I remove my Kcup, and let the machine process a large cup of water. After that, it runs perfectly.... well, until the next time the Ghost appears.
maryann.
Posted on Jun 04, 2010
  • 58 Answers
SOURCE: Keurig platinum only makes 1/2 cup
call customer service 1-866-901-BREW (2739)
Posted on Jun 22, 2010
  • 58 Answers
SOURCE: Keurig Platinum B70 Coffee Maker stops working and
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
  • 5370 Answers
SOURCE: My 2-year old Keurig Platinum
Click this link directly to disassemble the unit and also see the internal parts diagram:--- http://technoanswers.blogspot.com/2011/02/how-to-disassemble-keurig-platinum-b70.html ------------ keep updated. Thanks.Helpmech.
Posted on Feb 08, 2011
Every morning my Keurig is turned off
The Keurig B70 has an auto off feature that needs to be programmed. You can find the instructions here:
http://www.ehow.com/how_7389997_reset-keurig.html
Oct 17, 2014 | Keurig Platinum B70 Coffee Maker
How Do I Locate the fuses on a Keurig B70 Platinum coffeemaker?
To the best of my knowledge there are no fuses on the Keurig B70.
Mar 29, 2013 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker not de-scaling properly?
Purge and blow out the lines. Debis is in tubes and ports.
Jan 12, 2012 | Keurig Platinum B70 Coffee Maker
Keurig Platinum Coffee Maker shuts off and screen says "prime" at least a couple of times a week -
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Aug 28, 2011 | Keurig Platinum B70 Coffee Maker
Platinum B70 "brew temp set"
Brian, sorry, (re post ) with complete question? and make and model
May 11, 2011 | Keurig Platinum B70 Coffee Maker
Keurig Platinum Coffee Maker shuts off and screen says "prime" at least a couple of times a week - sometimes more frequent. Why?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 07, 2011 | Keurig Platinum B70 Coffee Maker
Keurig Platinum shuts off after one brew. Will
I came up with a very simple workaround to fix this issue:
http://www.nate-lewis.com/blog/?p=288
The problem is with the water tank not having a proper seal to the brewing unit.
Dec 28, 2009 | Keurig Platinum B70 Coffee Maker
Lost instruction manual
You can download manuals from the internet for free and then print them out. See the links below:
Keurig Platinum B70 Quick Start Guide Go to View/Download Page »
Keurig Platinum B70 Use & Care Guide Go to View/Download Page »
Apr 12, 2009 | Keurig B70 Coffee Maker
Keurig Platinum
Check to see if the timer was inadvertently changed to shut off at a certain time and then restart at another time. Go thru the menu on your B70 and i bet you will find that this is what happened.
Apr 11, 2008 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
517 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
