Question about Radio Communications
1.5kw how many watts - Radio Communications
    Problem Solver:
  • 18 Answers
1500.
A kilowatt is one thousand watts.
Posted on Nov 26, 2013
The wire in my house for an elec. garage heater is 14 gauge wire with a 15 amp breaker. I assume i need at least 10 gauge wire with 20 amp .The heater is 20.9 amps and 3000-5000 watts, with 17500 BTUs
Curt, a 20 amp breaker will blow if you pull 10.9 amps from it. I suggest having a licensed electrician do your wiring. Likely, you need a permit anyway.
Oct 22, 2015 | Water Heaters
Coleman 3500 with subaru engine no power to outlets
Hello there.
I'm assuming that engine runs fine. if there's no power output then the AVR or carbon brushes are dead. remove the back cover of the alternator very carefully and look at the center to find the rotor rings and check if the plastic brush holder hasn't melt or heat deformed and make sure the brushes make good contact against the rotor rings. if everything's fine then the AVR is dead. The AVR is a crescent shaped plastic container similar to this one.
http://www.ebay.com/itm/Automatic-Voltage-Regulator-AVR-For-5KW-5-5KW-Single-Phase-Gasoline-Generator-/221461125389
replace it with any similar found on Ebay, just make sure that connectors and cables are similar in shape and number. Regards
Jul 06, 2014 | Husky 3650 Watt Generator with Subaru...
Honda eu3000is. runs but not putting out the full watts. Is this a cheap or expensive fix?
I have the 5kw Honda and have no problem, but I have never tried to run 5,000 watts either. It is reaching max rpms? Air filter clean? Good fuel? Oil? Have you run it much, or does it sit? How do you measure the wattage? Add up a bunch of things like, skil saw, pump, fridge, etc? Let's see, skill saw at 13 amps x 120 volts =1560 watts. Fridge probably idles at 7amps, starter windings use 10 or so amps, tv, 500 watts, computer, I would not run anything electronic with a genny, unless I had a spike protector on it. Check it out, hope this helps.
Mar 05, 2011 | Honda 3000 Watt Portable Generator
What thickness of cable is required to the power point for a Mitsubishi MSWZGA71KIT is it 2.5mm or 6mm?
20 amps for every 5kw or 1amp for every 100 watts here is a simple wire size calculator http://www.gorhamschaffler.com/wire_size_calculator.html you can find amp draw and phase on the manufacters data plate on the side of the unit .
Nov 15, 2010 | Mitsubishi MSZ-A15NA Split System Air...
Generac model pp5000t 5KW generator, new, runs perfect but no output. tried flashing the field but still no output.
There is a technique for energizing the field, as just flashing a brushless will not work.
It involves two series 150 watt lamps between the utility power and the running generator. You can find it with Google.
Mar 22, 2010 | Electrical Supplies
Replacing engine on Powermate 5000W Generator
I would say, yes (given everything bolts up okay), but I wouldn't connect a full 5000-watt load to it.
May 30, 2009 | Coleman Powermate Portable Generator...
How many gal tank is the Powermate 6250 10 KW
Nearly all of the Powermates have the same 5 gallon fuel tank.
I'm a little confused, the Powermate 6250s are all 5Kw generators with 6250 watt surge ratings. Is yours really a 10Kw or did I misunderstand which generator you have?
Carl
Dec 12, 2008 | Coleman Powermate Premium Plus 6250W...
I need a 5kW DC generator with -48v output.
I have 5kW generators that produce -48V DC. The problem is that unless your generator is designed to produce -48V DC it would be difficult to retrofit an existing AC voltage output with a DC output.
Nov 25, 2008 | Kipor Electrical Supplies
Powermate 5000
20kw means 20 KILOwatts (kilo=1000), so 20kw=20,000 watts
So the Powermate 5000 refers to wattage. 5000=5kw
Sep 04, 2008 | Coleman Powermate Powermate 5000W...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
